A55 Smoothing Plane
Thank you TD!
Thank you TD!
Thank you TD!
Ed Kelle
>Thanks to TD, I upgraded the bearings in my Milwaulkee. He posted the part number of the sealed bearings, answered multiple questions of mine and today gave me detailed installation instructions. And good thing too, I was looking at the wrong bearings to replace. After about 2 hours or so of work, I have a drill that should last a good long time. And now I know how to do this procedure so I have no hesitation about opening the case up again. Yes, even though I blew it out with dust in the past, I was amazed at all the dust still inside the case.
Thanks for all your help TD, it is really appreciated!
Lets see... I buy a drill, upgrade the bearing in it, buy sanding discs from Steve Worcester, buy Russ' finishing DVDs and what do I do? Textured work! Go figure
Re: Thank you TD!
Re: Thank you TD!
Scott Hurley in N. VA
>I'd like the instructions on how to change the bearings, also. Could you forward them to me?
Thanks
Scott
Re: Thank you TD!
It's all in a day's work; YW Ed.
T Daniel
Re: Thank you TD!
mail!
Ed Kelle
Re: Thank you TD!
Better still, let us publish them as a WC article
Garrett in Victoria
Re: Thank you TD!
Some of us are mechanically challenged..
David
>and putting back together is not as easy as taking things apart. Putting back the trigger switch and the brushes on my Sioux was a little tricky. Have a new sealed bearing installed, but now a drill that does not function! I should have realized what my limitations were and left this bearing swap to someone who knew what he/she was doing. My drill is destined to be sent to a repair facility.
Re: Thank you TD!
which drill do you have?..
T Daniel
>forward/rev switch on top or at rear? Don't give up yet.
TD
Re: Thank you TD!
dont give up yet...
Ed Kelle
>If it was working before, and you did not remove any wires, it should work again. Check to see if the little part that contacts the bottom of the trigger lever is still there (in this the green part) . Mine fell out and I didn't notice until I tried to put the motor back in, it was under it.
The blue wire bushing goes in first when putting in the motor because it has to slip under a motor wire. Then the red wire bushing goes in pretty easy.
I rotated the whole motor assembley to make sure it was not hung up anywhere, and check to see that it is seated well in the housing, this can also keep it from spinning. Then I put in the remaining top end gears and went onto the trigger. Check the trigger rod direction as well and keep it all propped up while you put back on the case. I had to guess because of course it falls out when opening the case before I got to see how it went it. There is only one possible direction for it to be installed.
Hope this pic helps. I am sure you can do it yourself, the bearing was the hardest part of the upgrade and you got thru that OK. Keep us posted on your results
Re: Thank you TD!
Re: Better still, let us publish them as a WC arti
W.C. Turner
>I second Garrett's WC Article suggestion, & with pics if possible.
I've already got the bearings ordered.
