Lathe motor problems
Don in Denver
>seems that starter system (rather than run system) is again acting up on my Jet 1236. Last time I replaced the capacitor and took it to a motor repair shop.They did something to the contacts on the starter coil system. Cost me $50.Today I was turning and again the lathe wouldn't spin when I turned it on, just hummed. But if I spin it to get it started it takes off fine. New motor from Jet is $177 plus shipping. I'm going to get a new lathe next year (LOML assures me) but currently not an option. What do ya think? Replace or try to repair? The last repair was only done in Oct '05.
Re: Lathe motor problems
>Don I'm pretty sure if you spin it and it will run that it is the start capacitor. John
Don in Denver
>Thanks John I just replaced it in Oct. but I can do it again. I suspect there most be more wrong to be burning up capacitors so quickly.
James Brooks in GA.
>Don, I do not know what brand of motor that Jet uses. But I have been in the motor business for 30 years. You have two basic types of starting. One is with a mechanical rotating switch that mates with a stationary switch with contacts. The other would be an electronic switch. It seems that you may have a mechanical switch. When the contact make they send power to the capacitor. If dust or trash keeps the contacts from making, power cannot go through the capacitor and you will hear the hum. If you are mechanicaly inclined. Remove the motor from the lathe. Mark the end bells of the motor so you can position them back in the right place. Remove the end opposite of the shaft. If it is dust etc all you need to do is clean. If it is out of adjustment it will need to be bent a little in order to force the contacts together. Be carefull because if you bent it to much it will not break when the centrifugul switch moves it will not allow the points to break and will blow the capacitor. Unless the start winding is burned out , this should be a simple fix,even for a motor shop. If it is an electronic relay it will probably need to replace the relay. Good luck. On your next lathe you might consider a variable frequency drive.
Mike from St. Clair Shores
>Don,
My bandsaw did the same thing for about 3 or 4 years. I would just open the top before I pushed the switch and give the wheel a good pull at the same time I pressed the on button. It ran great so I never got it fixed. Then about 5 years ago I had the door open, pushed the on button and luckily my hand wasn't in the wheels spokes yet because it started up on its own and has been doing so since. Go Figure?
Mike
JKJ in East TN
>>Remove the end opposite of the shaft. If it is dust etc...
I had to do this to my old bench grinder twice in 30 years. It only took about 10 minutes.
JimQ
>Hey, if you only had it repaired 2 months ago, I would take it back to where you had it fixed and complain.
JimQ
Don in Denver
>Thanks James I had thought of myself as mechanically inclined until I read your comments. I don't know that I'm ready to tackle that kind of project. But I may take your comments with me when I go to the repair shop, if replacing the capacitor doesn't work.
Dennis Taylor
>I had a 1236 a year or so ago, and went thru the same problems...I replaced the starter cap twice..I talked with Jet, and finally I put on a a.c. surge supressor on the line to the lathe and also installed a a.c. protected power strip, after doing this I didn't have problems...Jet claim, I suppose they must of been right, that if there is a surge in the a.c. voltage comming into the shop, it will take out the cap, have to believe that is true didn't have problem after..I work for an Electronic company, so I got mine there, but you can pick up locally from Radio Shack or similar in your area..Don't have to be really expensive, I turn off, the power strip that runs the line a.c. surge, and that opens the circuit...I got rid of my 1236 after that, but for other reasons, had problems with the Reeves pulley's in it, over & over & over...but when she was running, it turned nice...hope this helps...Dennis
Don in Denver
>Dennis, thanks very much. This seems like an easy thing tp do. But to complicate matters further today it worked fine doing some light weight spindle turning, go figure.
