Have a question? Ask Woody!
turning small diameter dowels
Tom Sontag - St. Louis
>This is really a warning that you can expect a gusher of ignorance form this neck of the woods very soon. I have finally put gouge to spinning wood.
I have had a 40's era Delta wood lathe for two years without once installing a motor. Now I have a motor and am willing to be assimilated. A friend kindly showed me a thing or two tonight on his more modern Jet and a tiny tingly feeling entered my brain.
Anyway, the step pulley should arrive any day and I will have all the parts I thought I needed to make wood spin around. My first goal is to simply make some 3/8" dowels out of osage orange for an awesome workbench (another story, to be told on the main board within a couple of weeks I expect). But hammering that pointy mandrel onto my 1/2" square blank just splits it. Do I need a very small chuck or is there a secret to using madrels on small diameters? Like maybe a saw kerf "X" on the end?
Surely I could try that, but I am away from the shop now and really wanted to gloat a tad about the new world opening up before me. I hope to keep some flat work in the repertoire and use the lathe for simple spindle work. But I do have access to awesome wood and I see a big slope in front of me.
I am not much for classroom style learning. What beginner lathe book can tell me about the different cutting tools I got with my used lathe and when and how to use them?
Re: turning small diameter dowels
JKJ in East TN
>>...book can tell me about the different cutting tools...
Tom,
There are many good beginner books. I have several, but my favorites are:
The Fundamentals of Woodturning (Mike Darlow)
Turning Wood (Richard Raffan)
Woodturning, A Foundation Course (Keith Rowley)
I recommend getting more than one book. First of all, different authors explain the same things different ways which make many concepts easier to understand. Second, you'll learn a valuable lesson from the start - there is not one "right" way to do anything on the lathe. I think this helped me from being locked into a narrow and confining way of thinking.
Some people prefer videos to books, and I think videos are great. Raffan, for example, has videos that accompany many of his books. However a video cannot replace a book: there is SO much more information in a book than can possibly be fit into a video. Those who learn only from the video will miss much of the critical background material, alternative methods, and the "why" behind the "what". A bit like watching the movie without reading the novel.
Raymond Overman in SC
>How long are the dowels you're wanting to make? As long as they are less than 6 to 8 inches (maybe a little more) you should be able to produce enough pressure between centers with your headstock/tailstock to hold without banging on anything with a hammer. Take light cuts to round out the stock and ride the bevel of your gouge. If this is the first time you've ever turned, I might suggest you practice on a piece of scrap wood before eating away at your osage. I'd hate to see any of it go to waste as nice as it is.
>Tom If your new at turning your going to have trouble turning anything longer than about 3" when turning it down to 3/8". It takes a light touch. Don't drive anything into the ends just use the pressure from the tailstock to push against it. If you turn it between centers and need a 3" dowel make the blank about 4" long and turn just the middle.
An alternative way to do this is to drill a couple of holes in a piece of steel and just drive the wood though. Take some 1/4" steel and drill 1/2" holes in one side about 2/3 of the way through. Then flip it over and drill a 7/16" hole in one and a 3/8" hole in the other. Now just drive your blank through the hole and you have a 3/8" dowel. You could probably do it in one pass if you rip your blanks just a hair over 3/8". this is much quicker and more accurate than turning.
Mike from St. Clair Shores
>Without having to go out and buy a scroll chuck or some other expensive gadget this may be an easy alternative. I once turned about 400 muskie fishing lures. I made sure my blanks were all the same size, and I made an adaptor to screw on to a face plate. It was a piece of 2x4 or 2x6 that I made into a 3 1/2 inch circle about 1 1/2 inches thick. In the center I made a relief the size of the blanks about 1/2 inch deep. The blanks were tight in the relief on the head stock side and I just pulled the tail stock up with a revolving center and placed the point on the center of the previously marked blank. ( with a X )
Hope that wasn't to wordy and that it helps.
Mike
Scott Hogsten
>John has the the best idea but it you are determined to turn them on the lathe here are a couple of tips. 1 . Do this between cup centers instead of using a center with a drive spur (also you could use a steb center but these are more expensive). Things are much less exciting when you have a catch. 2. Get a 3/8 th inch wrench and use it as a caliper to help you determin size.
>Tom, Welcome to the round side. Be careful, that tingly feeling in your brain is seductive. You may never got back. The flat side of my shop just sits and looks longingly at the lathe, sometimes for months on end.
I generally agree with John Lucas on most everything, but I wonder about making dowels of Osage by driving them through a plate. I have done it with other woods, but my experience with Osage is that it is brittle and my guess is a fair number of them would shatter.
Many of us here turn Christmas Ornaments that involve long thin turnings. (Check out the ornament gallery that pops up in the middle right of the page.) A five or six inch dowel would just be a really dumb looking icicle. What I have done is to take my half inch stock and round a taper on the end about 3/4" long that matches the taper on my drive center. I just turn my belt sander upside down and roll the end of the stick on it and eyeball a taper. Then I use a mallet or handy block of wood and pound it (firmly but gently) into the shaft of the lathe in the headstock. Bring up the tail stock and tap the stick into position until it is nearly centered and tighten the tail stock. I use a ball bearing cup center with a ice pick like point in it. I do not use my cone center for this as it would split the wood. Then I just turn the dowel, using either calipers or the wrench suggested above, part it off and tap the little plug out of the head stock and go again. This is a little tricky if you want to sand the dowel you need to leave it a bit over sized and sand it the last little bit.
By mounting the stick directly into the head stock, you do not have to have a steb center or a chuck. (Trust me, if the turning bug bites, you will be getting a chuck and plenty of new toys.)
As a joke I turned a nine foot long dowel on my lathe which has a two foot bed. I ripped a stick and knocked the corners off with a hand plane. I passed the stick through the headstock and my chuck and used the chuck to drive the stick. Mounted an Eye bolt to serve to steady the stick behind the lathe. I turned the dowel about six inches and then advanced it about six inches and turned more. Passed it through the tail stock to steady it. Kept advancing it and turning more. I could have made a hundred foot long dowel it I had a long enough stick and enough eye bolts in a line to eliminate the whipping.
