What is a bowl skew?
Terry Quiram, Roanoke Illinois
>Grazing the internet this morning and saw an add for a Dave Hout bowl skew. I am not familiar with this tool. Does anyone use this tool. How is it used? What are your opinions?
Terry
Re: What is a bowl skew?
Re: What is a bowl skew? *LINK*
Jennifer@Indy.USA
>Looks interesting Terry. I've never heard of them either?
Bowl Skew
>Sort of a cross between a scraper and a bowl gouge?
>I think that is a pretty good description. It's kind of like shear scraping. If you tilt your scraper to about 45 degrees and pull it across the wood you get the same kind of cut. However it's difficult to pull a scraper from the rim down to the bottom of a bowl which is the proper way to cut a side grain bowl. With the bowl skew you can cut from the rim down pretty easily.
>Oh great. Another must have tool - sigh.
Bob Hackett
>If you grind your bowl gouge wings back a ways(the "irish grind") you have a bowl skew for the exterior.Use TD`s approach with the handle down at mid thigh and the cutting edge almost straight up and down.Cut on the equator or slightly below.
For a skew type finishing cut on the interior just grind your bowl gouge like Peter Childs used to recommend(I`m showing my age now),square across.Slightly round off the sharp corners and present the edge as close to vertical as possible without digging the corner in and getting a horrendous catch.This is an advanced cut as it skates on disaster`s dooryard.
If you understand the mechanics of the cut then most times a specialized tool becomes redundant.
Mainely,Bob
Mike from St. Clair Shores
>I went to a two day seminar by Dave Hout several months ago in Ann Arbor, MI.
The gouge that you are asking about is made from bar stock (rectangular) not round. It has a flute ground into it, and is sharpened like a bowl gouge. When Dave Hout taught the class he made it very clear that the way he cut with it (like a skew) it was virtually impossible to get a catch. I think that a video of his method is something that is needed to try to use it as he does. By the way, he is an excellent turner and teacher. If you get a chance to see him don't miss it.
My 2 cents
Mike
Bowl skew? Geometery and usage.
Ed Moore
>Two years ago at the OVWG Symposium I saw Dave Hout demonstrate the tool and he had each of us try it. Yes, I bought one. Start with a rectangular piece of stock that is 3/8 x 5/8" and grind a flute on the wide side that is 3/16" deep and extends from one edge to the other. Its cross-section is shallower than a bowl gouge and deeper than a spindle gouge, with two vertical sides and a flat bottom.
To sharpen this tool, imagine that it is a traditional bowl gouge, put the end in the wolverine and grind so as to get a blunt bevel. Then, grind a secondary bevel so as to remove some of the heel of the first bevel.
To use this on the inside of a bowl, rotate the tool 90 degrees so that the right side is flat on the tool rest. Keep it flat and do not rotate the tool. Adjust the cut by dropping your right hand slightly. Think of this tool as being used to clean up the transition portion between the side and the bottom of the bowl. I regard it as sort of a "tweener". If you extend the tool into the bowl and adjust so that you are getting a cut then the cut will be a shear cut just below the center of the tool. Actually, you should try this with the lathe turned off and rotate the bowl by hand before you just dive in with the lathe on.
From my perspective the tool is better theoretically than it is practically. Possibly it deserves a second chance, but I have sort of moved on. In fairness, it did not produce catches, even though that square edge on the bottom looks like it will grab everything in sight.
Ed Moore
SW VA
Re: Bowl skew? Geometry and usage.
Ed Moore
>I can spell, I just can't type worth a hoot.
Ed
Thanks everyone.
