My Back is Killing me!
Jennifer@Indy.USA
>Hey everyone, I need some design ideas, plans, pictures for building a log cutting cradle. I spent a good part of yesterday cutting logs into bowl blanks with the logs 6" off the ground on railroad ties and my back is severely not happy. I could barely get out of bed this morning! I have vowed not to cut one more log until I devise some way to get the logs up higher. That bending over while cutting with the chainsaw is without a doubt the worst position as far as my back is concerned....and I always wear a heavy duty back support too. So any help that you may offer to give me ideas for building one of these would be most definitely appreciated. My son is getting too heavy to be a rolling pin on my back!
Thank you :)
Jennifer
Re: My Back is Killing me!
David Propst
>Hey Jen,
Sorry about the back. Been there, done that. Look at Dave Peeble's website. I think he has a picture of a cradle built from 2x6's.
Did ya get some good wood?
David
Re: My Back is Killing me! *LINK*
Mike Cunningham (Cape May)
>Hi Jen,
I have one of these cranes that I use in the receiver of my pickup, however you could mount one in your yard/log cutting area to hoist the logs onto a "cutting platform" that you build from 6X6's, etc. I chainsaw my blanks while they sit in a V-notch that I cut into the top flat of a large diameter oak.
Crane
>Jennifer I have been looking at the same thing. There's only one problem and that is cutting the log up to a size that you can easily pick up so you have 2 problems. One is the initial cutting and the other is picking those darn heavy things up to put them on some kind of cutting fixture.
I am going to buy one of the log peavy's or lumber jack, whatever you call them. This gets the wood off the ground about 8" or so which is a little easier on your body and keeps the blade out of the ground.
Right now I roll the logs onto other logs to get them up a little higher but they are still to low. I too am looking for a good system to hold the logs while cutting becuase my back hurts also. One of my friends sat a big log up on it's end and then drove a nial in the center and cut head off. He plops the wood on the nail and it helps hold it while he's cutting. Another friend uses 2 X braces with wood inbetween. It's sort of a stand and works really well for bucking off the end of logs but not as good for ripping.
I did see somewhere a stand that was made from plywood, it had a bunch of sections that had a flat on one side and V's on the other and the whole thing was bolted togehter with allthead. You flipped it so the flat side was up to rip lumber or round off bowl blanks and then flip it over to hold round logs for crosscutting. Other than having to flip the whole thing this looked like a really good solution for me.
Rick in Lincoln
>Jennifer, Darrell Feltmate has a design for cheap and renewable sawbuck on his site that I've build and used for a while. It does save the back getting those logs off the ground!
sawbuck plans
Scott Hogsten
>I use a large log turned on end with a "V" cut in the top. I don't turn really big stuff so I cut the corners off on my bandsaw. Something to consider when making something to hold the log for ripping is to make sure you don't make it too high. You still want to be able to lock your arms for proper and comfortable saw control.
Scott Hogsten
Mike Schwing from Md.
>Damn. Cute girl running a chainsaw.
Tease!
That same thing hurts me, too. Goes away in a day. I can't lift the logs I'm cutting anyway. I've considered digging a pit and standing in it so I can cut at a more comfortable level. But we've met and you know I'm pretty much ground level as it is, so I figure it won't help much anyway.
If she would lose the high heels it would help too
David Propst
Steven Antonucci
You could lift weights?
steve antonucci
>Ah yes, the proverbial big lathe problem. You can swing more than you can lift...
I had a white oak bowl that I turned on my Nova a couple of years back. The blank was roughly 22" x7" and weighed 110# before I began roughing. Someone at WoodCentral asked me how I got it on the lathe, and my response was "I just picked it up..."
When I cut the tree (where it had fallen), the slabs were well beyond my ability to "just pick up", so I used an ancient Egyptian method of levering the 300-400# slabs. You lift one side with a lever, and then block under it. Then, you move to the otherside, and repeat. In my case, I just needed to get the one side high enough to get over the tailgate of my truck. Once it was on the tailgate, physics takes over, and you only have to lift a portion of the weight. Same principals apply to the ground and trimming.
Steve
BTW- Here a picture of a tree that I'm going to practice what I preach on...
pffshh..you call that a tree?
Why didn't I think of that!
Jennifer@Indy.USA
>David,
How silly of me! Okay I just cut the heels off on the bandsaw...I'll see how that works....but those pointy toes...sooo painful! What's a woman to do?
Yeow!
Dawn Adams
>I made one of these sawbucks and it works GREAT. I was having trouble with my back as well. This makes the work so much more enjoyable.
Jennifer@Indy.USA
>Rick thanks for the link! Great web page with lots of good tips. That is just the sort of thing I was looking for...the visual of how it's put together is perfect. Thank you!
Jen
Hey Dawn!
>Glad to see you made it here. You'll find lots of good stuff!
Steven Antonucci
You wouldn't need to bend over to cut it... ;-)
steve antonucci
>I'm always dismayed by how the tree service people handle these things... Seems to me that they could "double" their profits by handling certain logs differently. This one would have made some really nice salad bowls.
I guess I'll just settle for a bunch of 10"x10" hollowforms.
Steve
Re: You wouldn't need to bend over to cut it... ;-
>Around here they cut them similarly. Cutters that don't have cranes cut them into sizes that 2 guys can throw into a truck. Of course the dimensions I want are always cut so the most I can make is a 10" bowl. Argh.
Tree trimmers
>What they should do is leave them in 6 foot lengths, seal the ends and put up a sign that says "Free wood for Woodturners" It would all dissapear in a few days.
Re: Jen, how about this one?
>Bob That's the one I was talking about. What kind of lumber did you use? pressure treated lumber in that size would be kind of high and I would think the endgrain would absorb moisture and crack pretty easily. Exterior grade plywood might be too flimsy.
Ooops can't read
>Ooops sorry didn't read far enough. I need to leave mine outside. I don't think MDF would hold up unless I coat it with epoxy or something.
Ed Kelle
>My version is not very high at all, but then again my back would hurt me more from trying to lift things higher. They bolt to the boars which bolts inside the crate. I can move this anywhere I want, even take it downstairs and use it with the electric saw also. It can carry my chainsaw lube, gloves, visor, and other supplies as well.
The high brackets let me rip thru without cutting apart the holder.
Feel better!
>Ed You could always stack up 2 crates for smaller stuff to save your back. I like your idea.
You guys are great!
Jennifer@Indy.USA
>Thanks everybody for all the great ideas. Just what I needed to get started on putting one of these together. I think this might just be my Christmas break project.
Happy Thanksgiving!
Jen
Brian Hahn in SW Wisconsin
>There is a nice one that was originally published in the Minnesota Woodturners Association newsletter, the October 2004 issue. (It is a PDF file.) Hopefully this link will work...
Minnesota Woodturners Oct 2004 Newsletter
Brad Vietje
You need "Vitamin I" !
Brad Vietje
>Yup -- Ibuprofin; which my 24 year-old, incredibly athletic son calls "I Be Broken" when he's picking on his mom or the old man about our aches and pains.
Been there/Done that on the sore back, and yes, a cradle to hold the wood higher does help, but Vitamin I will help in the meantime.
Happy Thanksgiving,
Brad Vietje
Thetford, VT
