Lathe recommendation
Pat
>I to have the a Delta 46-700 lathe that was mentioned in a previous post, I'm looking to upgrade, can anyone recommend a good lathe that I could grow into for bowl turning?
Pat
Re: Lathe recommendation
David
>Seems like we all go through this. I have been turning part-time on a Nova 3000 with a Leeson 1-1/2 hp motor for about 4 years, and it has served me well. Looking for more power and size in what will be my final lathe purchase. I have considered Oneway, VB36, Powermatic, Vicmarc, Stubby, and Vega. Bill Grumbine makes a good case for the Vega 2600 that he recently purchased. If money were no object, I would get a VB36. Since I do have a budget, after considering value for the price I ordered a Vicmarc VL300. Will let you know how it turns out.
>Pat You'll have to give us a price range. I stepped up (or down) to a Nova Comet which is a mini lathe. It had so much less vibration my turning improved greatly. Then I went to a Nova 3000 which I liked but it wanted to walk a lot when turing bowls. Even with a big heavy homemade stand. I stepped up again to the Powermatic 3520. It was definitely worth it. If you don't want to go that far the Jet 1642 is a great lathe.
Vicmarc.fan
>I love mine. Just curious, where did you get your lathe. My dealer dosen't answer his phone or reply to e-mails anymore.
Ron
Powermatic 3520
>Hi John,
I am looking for a replacement for my Nova 3000, as this one happened to be a lemon and i am thinking Powermatic 3520, the size of the spindle and the post of the tool rest will have be the same, or I will look elswhere. The spindle must be 1 1/4" - 8 and the post 1", that way all my present toolrests and chucks can be used.
Also I heard something about versions A and B, which is the one to get?
Thanks
Jorge
Craft Supply, Provo
David
Re: Powermatic 3520
David
>The Vicmarc VL300 from Craft Supply has a 1-1/4' x 8 spindle, which is the same as the Nova 3000 I presently have. Should be able to use the vacuum system on the Vicmarc too. I think that in other markets the Vicmarc spindle thread may be different, but I am not positive on this.
Re: Powermatic 3520
Allan Johanson
>Not sure about the VL300, but my Vicmarc VL175 has a 30mm tool rest post. That works out to approx 1.18".
Cheers,
Allan
They Match
Clem Wixted
>The Powermatic 3520 uses 1-1/4 X 8 on it's spindle and 1 inch posts.
Clem
Re: Powermatic 3520
Bob Hackett
>Jorge,
The toolrest is 1" and the spindle thread can be brought to just about anything by an adapter.The adapter will give you better access to the back of whatever you`re turning,an added plus.My brother brought his up to 1 1/2-8 this way.I believe Mike Schwing also recommended an adapter awhile back.He could probably tell you where the best deal is on a high quality unit.
Glad to hear you`re trading up again.Any luck getting them to take the lemon back?
Mainely,Bob
Re: Powermatic 3520 *LINK*
>There is a really good write up on the AAW forum about the differences in the A and B. It seems like the B is worth the extra money only if you think you might be buying those accessories for the A that come on the B. Other than that most of the features on the B are relatively minor.
http://www.woodturner.org/vbforum/forumdisplay.php?f=2
Thank you guys,
>That is good news.
Jorge
Re: Powermatic 3520
>Hi Bob,
You are right, I forgot all about adapters, as a matter of fact I already have one that lets me use both my chucks, is good to know that the tool rest is the right size, I don't have as many tool rests as you but I am working on it, : )
I still need a definite go ahead from LOML, and I will star the procedure to return the late very soon.
Thanks
Jorge
Re: Powermatic 3520
>John,
I'll study it carefully, that is all I needed to know.
Thanks for the link
Jorge
