THE WOODRAT IS BACK!
Delta Lathe
Delta Lathe
Delta Lathe
G Mac
>I have an offer to pick up a Delta Model 46-700C Lathe for a decent price. It also comes with ONEWAY chuck with # 1 & #2 jaws, 3" & 6" faceplates, live centre & drill chuck, 8 piece FREUD chisel set in addition to 8 assorted SORBY chisels. I was wondering if this is a decent starter lathe? Or will it be more problems than its worth?
Haven't turned since I was in school about 20 years ago, so I am basically a beginner.
Thanks for all your help
Re: Delta Lathe
Re: Delta Lathe
Mike from St. Clair Shores
>What is the decent price that you are thinking of paying?
Re: Delta Lathe
Re: Delta Lathe
G Mac
>$650 Cdn or $546 US
Re: Delta Lathe
Re: Delta Lathe
>It's not a bad lathe but I think that's too much money. I think you can buy a new model of that lathe for just a hair more but I would have to look to be sure. I would pay about 300, maybe 350. I sold mine and bought a mini lathe. I think the jet mini lathe is actually a better lathe than the delta. It had less vibration and worked better. It didn't have a swiveling head and won't turn 12 inches but the lack of vibration is worth the difference.
Re: Delta Lathe
Re: Delta Lathe
>Too much. I would offer a lot less.
Re: Delta Lathe
Re: Delta Lathe
>I just looked in the Tool Crib. You can buy a new Delta 14" for $549. This is a much better lathe than the 46-700.
Re: Delta Lathe
Re: Delta Lathe
G Mac
>Hi John,
I was thinking the same as you as to the price, but I was also factoring in the accessories that come with the lathe as I will have to purchase these too.
Thanks for your response,
G Mac
Re: Delta Lathe
Re: Delta Lathe
Georg Waldhof
>I started on one of these lathes. Used in 1997 it was about $200 and didn't come with any of the tools you mention. You can get the same lathe used off e-bay for that price, sometime less. Vibration is an issue as this is not a particularly heavy lathe. Also, forget about turning the head to do outboard turning: you might tip the whole thing over and it will take a while to get the headstock to line up with the tail once you swing it back.
As far as price goes, a oneway chuck is less than $200 even with the jaws mentioned. The regular Oneway also requires two tools to tighten - the newer Talon or Stronghold has only one and they run $209 - $260. The turning tools sound good, but if they are carbide instead of HSS, that reduces their value. Carbide can be had for less than $30/tool. HSS varies but the brands you mention usually start about $25 each and go up depending on the tool. I would avoid carbide and invest in the better/newer HSS tools.
One could argue that will all those tools and the chuck, $550 might seem reasonable - it all depends on what you want or are willing to pay. Frankly, the tools and chuck are worth more than the lathe (at least in my opinion and provided they are sound and quality).
Might see if the guy will negotiate.
You also have to consider how serious you think you might want to get about turning. This lathe will be perfectly adequate for the occasional piece of small to modest size, provided you bolt it to the stand and add some weight. It is not a bad starter lathe, but if you start to do much turning you will exceed its capability quickly. I also personally found that the lathe's shortcomings made me less than enthusiastic about using it, so I did not do much turning. Once I invested in an old Oliver 2159 (14") I started turning almost daily, and even began designing my art and furnishings with turnings just so I could use it (and make it pay for itself).
For $700 - $1200 you can get a heavy duty lathe like a Powermatic 45 or 90, Oliver 159 or 2159, or even one of the big old Rockwells. Some of these are in a class with Oneway's lathes which go for around $3000. Before pursuing the used/old lathe market, however, do extensive research at the Old Woodworking Machinery website. Learn all you can about what you want, and inspect it closely if at all possible before buying.
Good luck
G
Re: Delta Lathe
Thanks Georg! Great insight and advice
G Mac
Re: Delta Lathe
Re: Delta Lathe
Don Tewell
>George,
What is the web site for the old wookworkers tool site you mentioned.
Re: Delta Lathe
Re: Delta Lathe
Earl Eyre
>I also had the same lathe and I hate to say it, but it was a pain. The Reeves drive was always sticking, the vibration was impossible to dampen, the bearings went out when I tried a fairly deep hollowing. My friend had a Jet mini and had much more fun on it than I did on the Delta. Personally, if that was my budget, I'd buy the Jet and all the accessories. I finally got rid of it and bought a Powermatic. Now I love turning.
If you could get it for $200 or $250 US then it would be worth it for the accessories. You can still buy somthing else when you get tired of the Delta, which will be soon if you do any serious turning.
Earl
Re: Delta Lathe
Re: Delta Lathe
Don Evans
>Its:
http://www.owwm.com/
Don
Re: Delta Lathe
Re: Delta Lathe *LINK*
Georg Waldhof
>here's the link. Best thing going for old machines.
OWWM
