New to turning may buy a lathe
Cameron
>I bought a very poor lathe (harbor freight I think) from a guy at work a year ago for cheap ($50 lost...). Went out and bought a set of tools from woodcraft and turned an 8" piece of walnut into a small cylinder and discovered 2 things: 1. the guys on TV make it look too easy and 2. that lathe is junk. The drive head flexes so bad that I couldn't really get it securely fixed in with the tail. Also every time I put a tool to the piece the head would noticable move..., haven't used it since. anyways..
I found a Nova 3000 with a Leason variable speed motor for sale in the paper for $800 (says never used.) Any thoughts on this lathe/price? That's definately at the top of my price range right now considering I've turn 1 scrap piece of wood and I'm not a natural... I hope to turn legs for furniture and maybe some vessels down the road if I can learn how to do it...
Re: New to turning may buy a lathe
>Cameron That's not a bad price. I think they sold for around $1000 new. I'm not aware of a variable speed Leeson motor. The Nova does have step pulleys and they are easy to adjust to give you speeds from 500 to 2500 or so. It's a good lathe. I used mine extensively until I stepped up to a bigger lathe.
If I had $800 to spend....
TDaniel
>and mainly wanted to turn table legs and spindles I would spend about $400 to $500 for a good used lathe, $150 for a day's instruction with a good teacher, and the rest for the best grinder I could afford. If you plan to do bowls then you will also need a half inch bowl gouge ($60), a jig to sharpen it with ($129), and a chuck ($89 up). You casually mention doing bowls and such; be aware that to turn bowls you really need a totally diferent lathe. All old lathes were basically spindle lathes; the Nova you have found would be a fairly good combination lathe and the price isn't bad.
Mike from St. Clair Shores
>Cameron, what you need to decide is if you intend to persue this turning bug and how far you want to take it. I don't know where you live, but if you are near a big city chances are good that there is a chapter of the American Association of Woodturners. Most chapters offer a mentoring program and the club will also be a good source to meet other turners. The Nova doesn't sound like a bad deal, but good deals come around fairly often. Meeting club members and going to various members shops you can experience turning on a variety of lathes. There are many different ways to approach this and these are justs my two cents.
Bill Grumbine (Kutztown PA)
>Hi Cameron
I used to own a Nova TK 1500 with a variable speed Leeson motor on it. It was very similar to the 3000 you describe, the headstock, motor, and tailstock being identical. The only real difference was the ways. The price you are quoting would be similar to the lathe with a plain old AC fixed speed motor. The variable speed DC motor added another $300 - $400 to the original cost, so if the lathe is in good shape, it is a deal.
Lessons are always a good idea, but then I am biased. ;-) Even if you can find someone in a local chapter to spend an afternoon with you, you will be miles ahead of trying to figure it all out on your own.
Good luck with it, and be sure to let us know how you do.
Bill
Scott Greaves in Blackfoot Idaho
>Don't Do It!!! Woodturning is a big black hole! You'll never be the same again!
Oh well, it's probably too late anyway! ;-)
I think you would be well served by that lathe, and the price seems reasonable. At that price all you could do is go down a lot in quality, or go up a lot in price. That is a good lathe for a good price!
Scott.
This would be a good start
Guy in Cuba
>Check the nearest Woodcraft, Rockler, or other woodworking store for classes. I know I have thoroughly enjoyed the ones I have attended.
I have had good luck with my Harbor Freight lathe, although I did upgrade it with a Super Nova Chuck and better tool rests.
Getting started you might consider the current deal at Amazon on the following Jet Lathe. This will leave you some money for some good HSS tools and a good jaw chuck. I think then you would be very pleased with your turning.
Jet 708351B/JML-1014 14" Mini Lathe
Price: $274.99 and this item ships for FREE with Super Saver Shipping. See details
You Save: $114.01 (29%)
Mail-In Rebate: $25.00
Price After Mail-In Rebate: $249.99
Good luck, Guy
The Wood Spinner / Bill Hale
>You say the guy on TV makes it look easy. The higher the quality of the lathe the easier it seems. Patience and a good lathe help.
Join a club, get a mentor and for a good bottle of wine he or she may give you a couple of free lessons, or just watching a turner and then trying to duplicate what they did also helps.
This site is also great for asking questions and getting help.
Good turning and be safe
Bill in Casa Grande, AZ.
