More minis - inspired by Jennifer (via Molly)
Rob Ceraso
>When I first saw Jennifer's minis, I thought I just had to try a couple with that box of exotic scraps I've been saving. Then I saw Molly's and decided to try this...
The vase is 124 pieces of maple, chechen, padauk and ebony. The bowl is 100 pieces of padauk, maple, chechen, and jatoba.
Thanks Molly and Jennifer for the inspiration. Comments welcome.
Rob
Re: More minis - inspired by Jennifer (via Molly)
another pic
Rob Ceraso
Re: another pic
>Outstanding rob. Those are very well done.
Re: another pic
David Breth
>124 pieces? 100 pieces? Takes a lot of patience to count pieces of sawdust! Those are incredible. Very, very pretty pieces.
Gary Ratajczak
>Awesome job!! I have had segmented minis on my to do list for a while. Just curious on what glue you have used. I was worried about yellow glue leaving a visible line. Also, still not sure on the long term use of CA. I have read a number of posts, and many state that it may degrade over a long period. Any comments on this subject appreciated. Again - terrific work!!!
Jennifer@Indy.USA
>Rob, these are fantastic! My goodness.....those tiny little bits of wood....amazing!
Jen :)
Rob Ceraso
>Hi Gary -
Thank you for the comments. I used Titbond II which normally does not leave a line even on lighter woods. On the vase there are a couple of dark glue lines in the maple but I believe that's just from dirt that was on my fingers while assembling the pieces (hard to keep your fingers out of the glue when the pieces are that small).
Thanks again,
Rob
Re: another pic
Mike from St. Clair Shores
>After the first pic I thought what a great job. Then the second pic with a quarter next to them, I thought what an incredible job. I guess the 42 X 1 1/2 inch hollowing rig I just made seems a little redundant. What was the size of the tool you hollowed the vase with? Any pics of it possible?
Thanks, Mike
Re: another pic
Rob Ceraso
>Thanks Mike.
Actually there's not really that much to it. One of the nice things about segmented turning is that each layer of segments is a ring with no center so theres very little actual hollowing to do. Better yet, I "hollowed" it before the top 2 segment rings and the collar were glued on - so it was still basically just a bowl.
Thanks again,
Rob
Awesome!
Brian Hahn in SW Wisconsin
>I've done standard size segemented turning and appreciate what it takes. Something on that scale with my size 12 fingers...
Smaller can be just as challenging, if not more challenging, than bigger. My hat's off to you.
Ed Kelle
>Those are amazing! What did you use to cut such small pieces? I think I'd end up with lots of little pieces glued all over myself
Rob Ceraso
>Thanks Ed,
Everything was cut on my big Grizzly cabinet saw with a zero clearance insert and a shop-made cut off jig. Unfortunately the blade acts like a fan and it kept blowing the pieces back into itself so it became an exercise in "how close can you get your fingers to the blade without losing one".
But it was fun....really.
Rob
Mark Kauder, Phenix City, AL
>Beautiful work, Rob.
Here is a hint for saving those little cutoffs.
Take a nylon stocking and stretch it loosly over the opening of a DC hose, and secure it with a rubberband. Position the DC hose near where you cutoffs are cut off. Turn the CD on. Now when you cut the pieces off, they will be sucked into the DC hose, but captured in the nylon. WOrks well when cutting with a CMS/SCMS, too.
Mark
Ed Kelle
>Thanks for the info. Keep up the great work and keep those fingers safe!
