lacing a large crack advice
ken chase
>I've see photos of what looked like leather laced through holes drilled on both sides of a large crack. I haven't done this but wish to and could use some imput on the proper technique and what material to use.
Help will be appreciated
Re: lacing a large crack advice
Sean Troy
>You might want to try several ways of stiching to get the best look and you'll get practice. Hand cut leather will make the piece look better than leather lacing. To cut the leather, just use a metal straight edge and exacto knife.
rawhide strips
TDaniel
>1/8" rawhide strips work good. Soak them in water for about 30 minutes before using and when they dry they will shrink and tighten up. To look good the holes must be evenly spaced in both directions.
TD
Re: rawhide strips
ken chase
>Thanks. Do I just tie a knot at the end of the process and is there any adhesive used?
Copper?
David
>I saw an example where somebody used copper (stripped house wire) for this purpose, and it looked great.
Brian McKearney
Brian McKearney
>For the one (and only) bowl that I laced, I used rawhide shoe laces. I drilled evenly spaced holes on each side and rather than knotting this lacing at the end, I threaded the end under the lacing and pulled it tight. One end ran under the lacing on the outside, and the other end was run under the lacing on the inside. At the time, I didn't know about the soaking trick, but my laces are still tight after 6-8 months.
Brian
Re: rawhide strips *LINK*
Rick Allen
>Some alternatives to standard laceing.
Different paterns to lace
Boot Lace
Craig Daymon
>We have a woodturner in our group, Norris White, who has been turning and stitching hollowforms and other turnings for quite some time now. He uses boot lace. He hits the tip of the lace with a little crazy glue to stiffen it and make it into a needle. Be forewarned, that he spends a great deal more time lacing the turnings than was spent turning them.
There may be a better term for the lace than boot lace, but it is the heavy cord used to stitch a pair of boots (as in sole to body), not the laces of the boot.
-Craig
jared
>rmove 1 for email
I used fine copper wire on some bowls. I like the looks of it and other people have complimented me on it too. I think I got it in the hardware section of a walmart. It is much finer than 18 gauge electrical wire. I think it was just called copper utility wire. The holes I drilled were only 1/16 inch I think and I used a needle nosed pliers to thread it through and then to twist a knot when I was done. Jared
Norm Smith in Nova Scotia
>Hi Ken,
All good advice already. My only suggestion is that you can but suede leather lacing in any colour, thickness and lenth at a good fabric store. I dont like the boot lacing as I found it too thick.
Good luck,
Norm
Re: lacing a large Thank You!
ken chase
>Now I have a good idea how to finish my project.
It is my first manzanita burl and a terriffic looking piece.
I'll post a photo when it's complete.
Thanks Again to all who responded
Jim Pugh, Ohio
>Hi Ken,
Something that I tried was to use standard shoelace for practice. It let me lace and unlace as often as I wanted. It also let me figure out how long a lace I needed before going to leather. The bowl I laced was more of a hollow form so I started at the open end of the bowl and the knot ended up at the bottom on the inside.
Re: many lacing alternatives
JamieDonaldson
>Here is a birch bowl my wife just laced with raffia, and we have used many other materials over the years to enhance cracks. Think "design opportunities!"
The Wood Spinner / Bill Hale
>If you use real rawhide and soak it you should also strech it before you do the lacing. It will strech a lot but when it dried it will shrink back. Do not over tighten as it could make new cracks at the lace holes.
Good turning and be safe
Bill in Casa Grande, AZ.
Dick Hines
Dick Hines
>I just finished a walnut burl that I had soaked in DNA but still got a chrack in the side. I used some brass. I got a thin sheet from a hobby store ans used a nibber to cut a 1/8' strip. Then I drilled holes on each side of the crack and used the brass for "stiching". I cut the brass to size and bent the ends so it looked like a staple. Then lightley taped it in the the holes. One staple on each side. Will post a picture tomorrow or the next day.
Craig Daymon
>Norm,
If you're talking about my posting titled, "Boot lace", please read the posting. It's possible, but I think we are talking about 2 different things. The lace I'm talking about is used to stitch the sole onto the boot, not to lace the boot. It's not terribly thick and looks great on turnings.
-Craig
