Slipped Ring Bowl - How to photos
Russ Fairfield
>There were several massages asking how I made this one. At least one of you has already figured it out. For the rest, here is how I did it.
I started with this bowl in the photo. I turned the outside to shape. It was made into a rather global form for the purpose of being able to use a round feature ring. Any other shape would riquire making either an eliptical ring or one that was very wide.
In the end, everyone likes the roundness of this bowl.
Re: Slipped Ring Bowl - How to photos
Re: Slipped Ring Bowl - How to photo 2
Russ Fairfield
>Then it was to the bandsaw to make the 1st cut.
Re: Slipped Ring Bowl - How to photo 3
Russ Fairfield
>The bowl was cut into 2 pieces.
Re: Slipped Ring Bowl - How to photo 4
Russ Fairfield
>The bar guide bar on the jig was relocated to make the 2nd cut to remove the tapered section. No special meansuements, just an eyeball guess.
The section that was removed is sitting on the saw table. This is the shape that will have to be made to replace it.
Re: Slipped Ring Bowl - How to photo 5
Russ Fairfield
>Here is the bowl with the replacement ring glued in place. The dimensions and taper are not an exact fit, but there is enough (barely) wood on the inside to make it round again.
The tapered rings were made as flat rings, and then sawn to the taper with an adjustable resaw fence. The ring was attached to the fence with carpet tape, and the entire fence pushed through the saw, using a guide bar in the table slot. All cuts were made with a 3/8 X 10tpi blade.
I sanded each ring to smooth the saw cuts with a 14" sanding disc attached to the outboard side of the lathe spindle.
I am making a 2nd bowl with the finished ring looking similar to this one, and another with 2 rings. The 2 ring bowl will have one like this, and another that is turned to smooth with the bowl form.
Re: Slipped Ring Bowl - How to photo 6
Russ Fairfield
>The finished bowl on the lathe. Turning the outside was easy. Turning the inside was a horror with the intermittent cuts. I did it with a bowl gouge, carefully.
Re: Slipped Ring Bowl - The finished bowl
Russ Fairfield
>This is the same photo that I had posted several weeks ago.
Bill Stehman ... AZ
>Thanks for sharing Russ, Your creativity is outstanding and the tapered ring brings it all out. Cutting the inside might make my hair stand !
Jorge Castaneda
>Very ingenious Russ, very laborious too.
Thank you for sharing your method
Keep 'em coming1
Jorge
Re: Slipped Ring Bowl - thanks for sharing
gary clarke
RevDoug
>Thank you, Russ. It's not often that a great will give a step-by-step how-to. You are indeed a gentleman.
Turn 'em round,
Ron in Drums PA
>Thanks Russ
Thank you Russ! & a Ques
Dominic Greco in Richboro PA
>Russ,
This is some GREAT information you're giving away here Russ! I hope this becomes an article! (Hint Hint Garrett!)
I read how you used the jig at the bandsaw to cut the tapered rings. Needless to say, it sounds a bit complicated,...but cool. However, I'm assuming you made the rings "whole" (one completed glued up ring) and then used the resaw fence jig to cut the taper. Is that right?
If so, then the resaw capacity of your bandsaw would limit the diameter of the feature ring you could taper. (not that this matters a heck of a lot). For larger rings, I guess if you had a surface sander, you could build a jig to taper the rings. Your thoughts?
See ya around,
Dominic
Re: Yes, and Yes
Russ Fairfield
>Dominic,
Yes, the tapered rings were cut whole; and yes, I am limited by the height of the bandsaw. However, I am now using a 9" riser block on the saw, so that gives me a 15" vertical cutting height. It seems to be working quite well, and I don't see any need for larger than that for awhile.
It was a challenge to figure out.
kevinT in T Bay
>Thank you Russ for the challange. You made many here think...Instead of rightout giving up the method... It helped to keep the mind sharper than usual lately. Some differences in how we attacked the project. But, this way here, I'm not trying just to "reproduce your hard work". Learning is one thing ,but just copying others work( to me is just wrong). Thanks for enlighting us.. KevinT
Curt Fuller
>Thanks much for the instructions and photos. I've gotta try that soon. Your bowl is just fantastic.
Russ, thank you very much ! and ...
Fred in NC
>The inside cut would give me nightmares. From your description it is a very irregular shape, and very prone to a catch.
I had been thinking (well, trying to, anyway) and now you brought back to my mind some ideas I had a while back. Originally it had to do with knots and other irregularities inside of a bowl. Some of those will also produce a nasty catch. My idea had to do with roughing the inside until light cuts could be safely done.
Simply put, it is a round-cutting router bit of sorts. The motor sitting at one end of a long handle, and the bit at the other end. I think it can be made out of a Foredom or similar tool. It needs to turn at a very high speed, in the order of 30,000 RPM, so the bit needs to be of small diameter. The bowl would need to turn at a slow speed while cutting. This might sound contrary to normal turning practices, but who knows ???
Ken Langenberger
>Nice bowl great idea and good photography to show details
Thanks Ken
albertabob
>Russ:
Very neat idea.
Is there a jamb chuck pulled into the bowl on Photo 5?.
I noticed the tailstock sitting close by in the pic.
Rgds
Bob
Rob Ceraso
>Russ -
Thank you for an excellent tutorial. You definitely got the creative juices flowing.
Rob
David
>Thanks for letting us see behind the curtain!
Russ Fairfield
>What you don't see is a plywood disc held against the top of the bowl to add support while I turned the outside. Then I used a steady rest on the outside while I turned the inside.
