REAL MILK PAINT
bowls---blaugh!
bowls---blaugh!
bowls---blaugh!
Dennis Taylor
>I have been trying to turn a few bowls, and all I seem to get are small ridges on the outside & inside that must be sanded away....I don't know if it is the tool, the approach or just I ain't very good at this yet...I seem to get the walls pretty equal throughout, but rough!....the inside I have been using a multi-tip tool, and it seems to smooth the bottom up, but tears up the end grain...any guidance!...Dennis
Re: bowls---blaugh!
Keith Tompkins
Re: bowls---blaugh!
Keith Tompkins
>Hhi Dennis, equal wall thickness is a great start. I suggest switching to a bowl gouge to cut the interior of the bowl, ride the bevel of the grind for a smooth cut. Try for a smooth, uninterrupted flow from rim to the base in the inside that mimics the exterior form. With practice, you'll be able to make one continuous cut.
Re: bowls---blaugh!
Re: bowls---blaugh!
Carole in VA
>In addition to what Keith said, don't try to push the tool too fast for the speed of the lathe. Either speed up the lathe or slow down with the tool. And don't give up...you'll get the hang of it! :)
Re: bowls---blaugh!
Re: bowls---blaugh!
Earl Eyre
>Another thing that causes ridges is pushing the tool against the wood too hard. Holding the gouge or scraper very steady and slowly, lightly move across the surface. When you hear a "tick, tick, tick" you know you are just cutting the ridges off. When you push into the wood you just keep riding up and down the ridges making them deeper.
The experts can hog off huge amounts of wood successfully. Until you get to that point, concentrate on taking fine ribbons of wood off...the lighter the touch the better.
Got this advice from Christian Burchard in a workshop...best woodturning advice I ever got.
Earl
Re: bowls---blaugh!
Re: bowls---blaugh!
JimQ
>Or you may be using just the point of the insert, not the longer edge.
JimQ
Re: bowls---blaugh!
Re: bowls---blaugh!
Bill MacLachlan
>I also am having problems lately doing the inside of bowls. The last few I have had catches and pulled the bowl right out of the chuck. I know I am cutting too deep and I assume it is the wrong tool angle. What is meant by "riding the tool" or however was mentioned? What angle should best for coming into the bowl? What height should the tool rest be?
Lots of questions but I seem to be getting worse rather than improving.
Thanks, Bill
Re: bowls---blaugh!
Re: bowls---blaugh!
DWFII
>And buy Bill Grumbine's video on bowl turning!
DW
In the High Desert of Central Oregon
Re: bowls---blaugh!
Re: bowls---blaugh!
David
>Bill & Dennis - see the post/question I asked the other day under the topic "Bowl end grain question". I think the responses there will help Dennis out, as he seems to be asking some of the same questions as I was.
Bill - I will try to answer the riding the bevel question. In order to cut the wood, say with a bowl gouge, the tip of the tool's blade must obviously be in contact with the wood. But at what angle? It sounds like you may be presenting the tool at a fairly severe angle to be chopping out wood. Almost like you are presenting a drill bit to the wood. The angle you want to use is the one on the tool. The bottom of the tool, where the angle is, leading to the tip is called the bevel. You want the bevel to be fairly "flat" against the wood (given that the wood is round as it comes toward you and the bevel is flat). Try raising or lowering the back of the tool some to get a feel for where the bevel is. This is something that becomes a practiced skill (I've only been doing this 9 months, sooo...). You'll know it when you do it - the feeling is pretty unmistakable, as well as the great feeling you get when you make a complete "pass" and are able to keep to tools angle (riding the bevel) in synch with the bowl all the way down. Your position with the tool on the wood will change as the curve of the bowl changes - the Bill Grumbine video that I will be getting for Christmas I understand is great for demonstrating this.
When you are truly on the bevel, you'll get some very professional looking shavings coming off that bowl - no dust, no chunks. And as you get better at it, you'll start to see that tool lines (circular lines around the bowl) start to disappear from your work.
I think you will find it easier to learn how to ride the bevel on the outside of the bowl. My experience anyway. The inside is a bit tricky to me. Also, be sure to stop the lathe frequently for a little while, until you get the hang of it. Make a pass, look at the wood, see how you did on that last pass.
Presentation of the tool to the wood will help you get on the bevel faster too. I'll let somebody else describe how to do that - I've probably done enough damage trying to help here!!!
David B.
Re: bowls---blaugh!
Peter Charles Fagg (UK)
Re: bowls---blaugh!
>Dennis, if it is any consolation, I only turn bowls and dishes and every one I make winds up being like an old washboard because I have real problems controlling my arm muscles. They overreact and I have a real struggle sometimes to avoid dig-ins or catches. Final cuts are a real pain and sanding is my only option. Sometimes I think I should be wearing a straight-jacket just to keep my arms from jumping and twitching.
Don't give up though, soon I will have been turning for 16 years and I still get inspired for more bowls etc. I just hate the sanding!
Regards Peter.
Re: bowls---blaugh!
Keith Tompkins
Re: bowls---blaugh!
Keith Tompkins
>Peter, the trick is to NOT rely on your arms for control...with a long handled bowl gouge, anchor the handle against your hip, and rotate your whole body to control the cut. Better control, less fatigue. Better results,too.
Re: bowls---blaugh!
Re: bowls---blaugh!
>Keith, over the years I have tried every possible combination to control my spasms but to no avail.
Thanks for the thought anyway, Peter.
Re: bowls---blaugh!
There's another way to go.
Phil Joines Krum, Texas
>A captive boring bar with the cutters made for bowls. I got into making them because LOML has arthritis. She can't use a gouge for more than 1/2 an hour a day. With the boring bar there's no strain on the body since the hands are just controlling the movement of the bar, not absorbing the force of the tool. The leading hand is resting on the tool rest and controlling the tool with back and forth movement of the fingers. With the cutter set properly there is almost no force needed and control is very easy.
I don't know of any commercial bars that have the needed design for cutting on the outside. If you know anyone local to you that makes conventional bars have them email me to discuss the shapes or I can make them.
Re: bowls---blaugh!
Keith Tompkins
Re: There's another way to go.
Keith Tompkins
>HI Phil, good idea....I have lyme disease, and the stress of turning sometimes causes my joints to seriously hurt. I have resorted to a captured system for hollow forms for this reason. That would be a great solution for bowls as well....
Re: bowls---blaugh!
>Sorry to hear that Keith.
What you need is a bar bent opposite the hollowing bars. If you have access to a hear source they are easy to make. I usually drill a 1/4" hole about 1/2" deep in the end of the bar, do the bend, it doesn't need to be a swan neck, and CA glue the preshaped cutter into the hole in the correct orientation. To make a scrapper tool I find it easier to make the bend first then cut a flat on the end. Drill and tap a screw hole to match what ever scraper blade you want to use. There are a number of replacement blades on the market. The length of the bend and diameter of the bar determines how large a bowl can be made. Of course the front tool rest is positioned much the same as when using a gouge. The rear support is the same an in normal hollowing.
I usually rough cut LOML's blanks on the band saw. When that's not possible I rough turn them for her.
It takes longer to finish a piece this way but it allows people to turn who couldn't otherwise. It's entirely possible for a one handed person or someone with pretty saveer disabilities to use it. If needed it could also be set up for sanding.
