Cool wood from dump and what I did with it
David
>I stopped by my favorite dead tree dropoff, and found two pieces that were effectively "pre-cut" into blanks. Both had checking on the ends, but looked like they could be saved, so I grabbed them, and turned them for a warping experiment.
But I have no earthly idea what the wood is - if you have any ideas (I love this question, because of the variety of responses it generates). They turned pretty easily, and I guess I don't know what else to tell you about them.
Here is the wood as found, and the next post down as well, then what I've done with them.
Re: Cool wood from dump and what I did with it
David
>Seriously weathered end grain.
David
>This is unfinished as of yet. When I turned it, I think I broke a few rules on warping stuff intentionally, but I put this through the complete regimen of sanding while on the lathe (and even a bit once it came off), to a "finish" level, knowing that once it came out of the paper bags (2), I would have to sand again anyway. My reasoning for finish-sanding it on the lathe was that the second time around the sanding wouldn't be so bad, and if I sanded while it was on the lathe, I had the benefit of "roundness", and I felt it would also help retard the drying a little bit, and maybe prevent some cracking. I've done this a few times, with no crackouts yet. And I have noticed very little in the way of hairs standing up that needed to be sanded back down whenever I've done this. This may be old hat to many of you, but the intentional warping thing is new to me, and I am really enjoying it. Next thing will be to try a pith-inclusive bowl (double-bullseye) to see how that goes.
This is about 4.5" inches long, by 4" wide (now that it has warped), and is more or less shaped like a canoe. I like it a lot, hope you do too. Also thought this picture showed the grain pattern a lot better to help identify the wood. By the way, the other piece I did with this wood worked out, but the shape wasn't as nifty as this one.
Thanks for looking! I think this is only the second or third time I've posted a photo of something I've made.
David
>By the way, I'm seeing a little bit of pink in the wood on the photos. That doesn't exist at all in the wood.
Roger
>David,
Don't know what part of the country you're in, but living in the east, it looks alot like white ash, both the bark and the turned piece.
Roger
David
>I'm in the Buffalo, NY area. White ash sounds like a possibility to me.
Kevin Turner
>David, No matter what folks say, I love to watch the wood wrap...I think its character...Nice piece , and to boot. FREE. KevinT in T Bay
JamieDonaldson
>I guess white ash as well, and with the width of the rings it must have grown near a good water source.
David
>Thanks for the comment, Roger. I really like the way pieces look when warped. I'm hoping over time to get some really crazy shapes, but I haven't really cracked the code on how to do that yet.
David B.
David
>Whoops - sorry Kevin. I read Rogers response, then yours, then got mixed up.
