scale for moisture wt.
gary clarke
>I need an accurate scale for weighing wood for moisture determination and would like to know what anyone is using other than the spring type kitchen scales. I will let my social security pay for it LOL.
gary clarke
Electronic scale for under $50
TDaniel
>I got mine at Sam's Club. It will weigh up to 300 lbs.
Re: scale for moisture wt.
>Gary I just use a bathroom scale with 2 25lb barbell weights on it. The theory is it wasn't designed for 3 to 5 lbs of weight but should be fairly accurate at 53 or 55. Seems to work for me. If I ever find some UPS scales used I'll probably by that.
JKJ in East TN
>You didn't mention the weight range and accuracy you need.
For relatively small pieces it's hard beat a laboratory triple-beam balance. I have an Ohaus that with aux weights will weigh 2610 grams or nearly 6 lbs to 1/10th gram. I used it recently while microwave drying some blanks for spindle turning.
I've had this scale for over 30 years - perhaps you can find one on Ebay.
Re: scale for moisture wt. *LINK*
AnthonyY
>I bought a digital scale on Ebay for under $30
http://cgi.ebay.com/36-DIGITAL-POSTAGE-SCALES-POSTAL-SHIPPING-SCALE-GRAY_W0QQitemZ5626134002QQcategoryZ50954QQrdZ1QQcmdZViewItem
question, why weight?
Kevin Turner
>now all of the posts are speaking about weight. Am I wasting time with the moisture meter? Just curious.... from wet behind the ears...LOL
JimQ
>I bought a 10lb postal scale at OfficeMax for about $45.
JimQ
Re: question, why weight?
>Kevin. By watching the weight you can tell when it stops losing weight. Then it is ready to re-turn. It's cheaper than a moisture meter especially if you already have scales.
JKJ in East TN
Not a waste of time!
The way I understand it, moisture meters are a good quick test but can be fooled. Pin type meters rely on how well the wood conducts electricity as measured between two contacts very near the surface of the wood. Physical and chemical variations in the wood can affect the accuracy. Core moisture can be measured with longer pins driven deep inside the wood.
Pinless meters can supposedly measure deeper but mine, for example, only claims to be good for about 3/4" deep. You can get a pretty good idea for an 8/4 board if you check from both sides. I suspect it averages the moisture gradient near the surface, but can't measure gradients like a pin meter. It also works best on a flat surface and is very dependent on the specific gravity of the wood. Mine requires setting a parameter for different types of wood according to a table.
Weighing the wood is a more precise way to either measure moisture content (especially for researchers and kiln operators) or roughly determine when the MC has stabilized. To determine the actual moisture content very accurately, weigh a small sample taken from inside the wood, remove every last bit of water in an oven, then weight again and calculate the MC from a simple formula. To get a good idea of when a wood has come to equilibrium with the ambient moisture, weigh until the weight no longer changes. This might take hours or days with a microwave oven, months or years by air drying. This is a good method for bowl blanks and rough turned bowls - just weigh and write the weight on the blank when first cut or turned then recheck every month or so. Note the change over time, or better, plot the curve and it will be obvious when it comes to equilibrium.
Either type of meter is far quicker than weighing and probably is fine for most purposes. I use my meter often to get a rough idea of moisture.
David
>As a cheap-guy alternative, I happen to live a few blocks from the post office, and the self-service scale is conveniently located just out of view of the service desk.
Thanks JKJ and JohnL. Very helpful..
Kevin Turner
>Would the examples still apply for someone that is into segmented bowls? I now understand the weight terminology stuff now...and it seems more geared to Natural turning materials. Cool... Thanks KevinT in T Bay
