Turning glove
Turning glove
Turning glove
Dawn Adams
>Does anyone here use a glove when turning. A large sized very sharp piece of wood flew off my blank the other day and stabbed my hand. OUCH! It was bleeding quite badly, so I put on a carving glove so I could finish turning my blank without blood getting everywhere (I could have taken the time to go upstairs and bandage it properly, but if I left the shop I may have gotten caught by chores needing to be done). I liked the way it felt turning with the glove on, but in the back of my mind I was very worried about catching the glove in the lathe. Could be dangerous. I have searched for posts on other boards and found varied responses (pros and cons for both sides). Any insights or war stories would be appreciated.
Thanks!
Re: Turning glove
Re: Turning glove
georgetroy
>Yes, I use golf gloves for my left hand. I have been whacked before and sitches were needed on my hand. I believe if I had been wearing my glof glove I might have escaped with out injury. I keep all the fingers in my glove, I do not cut them off. I have seen demos at symposiums were the turner who was full them had them for both hands. Some turners also cut the glove fingers off. Not me. GT
Re: Turning glove
Re: Turning glove
Ken Oakley-Sunny St. Cloud, Fla.
>I have seen many really bad accidents involving gloves and spinning machinery.I would prefer cuts,slices, ripping and piercing of flesh that can be repaired with stitches then some of the crippling damage done to fingers, hands, wrists, and arms when a glove gets caught on an object being spun by horse power forcing it to go from 800-1000 RPM or faster to zero Rpm instantly. Long hair coming into contact with a spining object can change your hairstyle in an instant also.
Maybe the fact that I started working with machinery 60+ years ago when gloves, long hair, loose clothing, finger rings were all no-no's make me old fashioned but I still have all digits, joints and appendages I started with 73 years ago. My $0.02 worth.
Re: Turning glove
Re: Turning glove
Devon Palmer
>Yeah, I wear either fingerless carpenter gloves or cycling gloves with Gel padding (helps with vibration, etc). I can only get a few months out of each pair as they get cut up, chewed up, and just worn out, its saved the side of my wrist many of time for a sharp bowl edge.
Good point on safety tho, usually only wear them for roughing out to limit the danger.
- Devo
Re: Turning glove
Re: Turning glove
>I will have to review my turning procedures. Years ago I wore gloves because I had the same problem with wood burning my hand or bark coming off and hitting my hand. I have turned 15 bowls in the last month all from rough stock and didn't even need a glove.
Here's what I think is the difference although I'm not 100 percent sure how I turned before. OK first I don't round the piece over by starting parallel to the bed and running back and forth to get the blank round. What I usually do now is start near the middle and true up the back working my way out toward the edge. I do this with the flute up rubbing the side of my side ground gouge. I try to get the gouge handle as low as possible so I'm getting a shearing cut which is a cleaner cut, safer and throws the shavings down and away from me.
As I start to round the bowl from bottom toward the rim I revert to a push cut with the flute pointing more or less to about 9 oclock. To keep from getting beat to death by either hitting a large out of round area or low spots I anchor the tool with my left hand and pivot the tool in an arc. This allows me to take a very controlled cut that is never too big. This is the basic technique I use to get the blank round and roughly to shape.
I think what I used to do is push on the bevel. This made the tool bounce in the high and low spots and really wore me out. By doing the levering cut with a big bowl gouge with a long heavy handle I can take 1/2 to 3/4" deep cuts and round off the bowl quite safely and quickly and haven't needed to wear a glove like I used to.
Not sure when or why I changed the way I was doing this. I know part of it was watching John Jordan demo. He was taking huge cuts and wasn't straining at all. I decided I was working too hard and there had to be a better way.
Hope this helps someone.
Re: Turning glove
Re: Turning glove
Darryl Hansen
>When the bark is loose an or the log dry I use a glove. The typr they sell in boat stores as sialing gloves work very well. The tips of the fingers are off and the glove fits so tight I don't fear getting it caught. The Iron Clad golves are also very tight anf rom fitting and have non slip surfaces on the fingers.
Re: Turning glove
Re: Turning glove
albertabob
>I wear cheap utility gloves through most of the turning process and always during the sanding.
Always have.
You need to use due diligence with gloves just as you do with your bare hands.
What possible advantage to your project accrues from burning your hands?
Bob
Re: Turning glove
Re: Turning glove
W.C. Turner
>I always wear gloves. Could it be dangerous? Of course, but, so can crossing the street! Life in itself is dangerous. Woodturning, woodworking is inherently dangerous. You must exert diligence regardless of the undertaking.
Re: Turning glove
Re: Turning glove
George Van in WI
>Thanks John, you helped me remember how I used to do it before I thought I had a faster way, somehow I got the pushing on the bevel idea and yes the ride is rougher. I guess I was trying to compensate with more speed which was the problem with vibration. I will try some of the maple blanks I chainsawed tonight first thing in the morning and go back to the old way.
Re: Turning glove
Re: Turning glove
JKJ in East TN
>There was a recent discussion here about wearing gloves at the lathe. Try the Search. In an industrial setting, I've always been told that using gloves around rotating things was dangerous. I found and listed some cases in the thread of serious and fatal injuries.
Re: Turning glove
Re: Turning glove
JimQ
>OSHA regulations FORBID the use of gloves when working on lathes, because of the risk of snagging the fabric with a spinning splinter.
JimQ
Re: Turning glove
Re: Turning glove
GeeSeaWhy
>I sometimes wear a glove for roughing the outside of bowls. Once the blank is down to round, the glove comes off. I also keep a box of bandaids in the shop, just in case.
Graeme
Re: Turning glove
Re: Turning glove, oxymoron? No, Much Worse!
>You've asked for advise. You've gotten excellent advise from those who warn you that gloves are exceedingly dangerous. You've also gotten opinions from some who continue to get away with wearing gloves. You have not gotten opinions from those who wore gloves but did not have good luck. They don't turn any more, or they don't type anymore. Some of them are dead, because the lathe started with the glove, proceeded to the hand, then the arm, and finally the rest of them. A JET mini might bog down somewhere around the wrist, but you really need to develop safe habits before you graduate to a big lathe.
I don't make this stuff up.
LOML does safety professionally. A colleague was on a job site, doing some analysis of the company's machine guarding, and working with an operator of an industrial lathe. He turned away, turned back, and the operator was GONE. The lathe snaged his hand, wrapped him around the spindle and killed him, instantaneously.
No gloves, no necktie, no long sleeves, no ring, no watch, no necklace, no iPod, no headphones, no pony tail, no handlebar moustache. I even tell the Benchdog, "no panting!" when he gets close to the lathe.
Re: Turning glove
albertabob
>" A colleague was on a job site, doing some analysis of the company's machine guarding, and working with an operator of an industrial lathe. He turned away, turned back, and the operator was GONE. The lathe snaged his hand, wrapped him around the spindle and killed him, instantaneously."
Was he wearing a glove?
Was he distracted by the presence of a stranger?
There are so many factors that contribute to "accidents".
Proper technique and safey should be mandatory for hobbiests that want to enjoy using large machinery.
Currently they are not and that produces the vast majority of problems.
I remember my basic training in the Army well enough to say that we are not all equal when it comes to dexterity, reflexes and problem solving.
Bob
Re: Turning glove
Re: Turning glove
The Wood Spinner / Bill Hale
>I am, at all times, safety minded. After reading this thread It comes to mind that a surgens rubber glove may be ok. The blue ones ar quite strong but will tear if you pull a little hard. They are tight fitting so should not have any catch potential but still give good finger sensativity.
Any thoughts
Good turning and be safe
Bill in Casa Grande, AZ.
Re: Turning glove
Re: Turning glove
JimQ
>But they wont give any protection from splinters which was the original point of the thread. They just keep the dirt off your hands and make them sweaty.
JimQ
Re: Turning glove
Re: Turning glove
>They also won't slide on the wood and will pull your hand in. Trust me on this one. I use them when I apply finishes and I have occasionally used them to apply finish when wood is spinning. Not a good idea, trust me.
Re: Turning glove
>What's the point of your questions?
Assuming he had not been wearing a glove, is your implication that perhaps if he had been wearing a glove he would not have been pulled into the lathe?
Assuming that the distraction was a contributing factor to the accident, are you implying that one should only use a lathe when there is absolutely no possibility of distraction, real or imagined, from any source?
The point I was trying to make with this anecdote is that lathes are dangerous, and we should try to do whatever we can to mitigate that danger. In this case, the issue that got the safety person involved was machine guarding, which if it had been implemented according to the industrial standards for this machine, should have prevented the worker from getting the catch that killed him. Wood lathes used in non-commercial, non-industrial applications, do not have these government-mandated safeguards, so the user has to use some intelligence to protect him or herself.
Re: Turning glove
I just can't agree with this one
TDaniel
>Bill, I have been involved in designing high speed machines for a good part of my life. I have seen some pretty bad accidents and sadly some of these were because of "safety guards". I have also grew up around old farm machinery with the long, flat belts driving saws and such with no guards and I still have all my fingers and limbs. I have nothing against safety guards when they are properly designed; unfortunately though, we now expect safety guards to protect us from everything and thus we have let our own "guard" down. We must always be careful (and thoughtful) when working around any machine. I worry much more about a person wiping the toolrest with his fingers while the lathe is still rotating than I do about a person wearing a snug fitting pair of gloves. If a person does not do anything with the gloves on that he would not do if not wearing gloves then I don't see any possibility of him getting hurt because of having gloves on. Perhaps if one was to extend the jaws out of the chuck body and then grab the chuck while still spinning the gloves could get tangled in the jaws and pull the operator into the lathe? If this is the case that we are talking about then I would suggest that this operator switch to a treadle lathe which would be much safer for him. I am groping here but I just can't see any other way that a tight fitting pair of gloves could become a problem.
Re: Turning glove
Re: I just can't agree with this one
Wally Dickerman in Arizona
>Terry, I agree. I ocassionally wear tight fitting golf gloves when a situation calls for it. Such as cutting dry wood when the tool and chips get hot, or when loose bark, etc. is apt to fly off the piece. My hand is always on the back side of the tool rest.
Wally
Re: Turning glove
JKJ in East TN
This doesn't make sense to me. IMHO: Although touching the turned object with the bare hand might be uncomfortable or even painful, the threads of a cloth glove can get caught on the wood and in a flash pull on connected threads and then pull the entire hand around the rotating part. Given a strong enough motor and workpiece and the arm follows. Such accidents have been documented by the safety industry and are the reason for prohibiting gloves around rotating machinery when it is in operation. Of course you will not have an accident if you never get near or touch a spinning part, but who can guarantee that will never happen even unintentionally, let alone while tired or distracted. Consider the definition of the word "accident".
Remember that people have lost fingers in their home workshops by polishing a piece on the lathe with a cloth with one end wrapped around the fingers. A demonstrator at our club described such an accident. This is why it is recommended to use paper towels or very tiny cloth squares instead of a larger cloth. Same thing with using steel wool on a turning part - it can catch in a flash (and is as strong as steel!)
A loose glove could certainly be a hazard if the hand comes near a part or machine component that protruded, such as a chuck. But whether a specific tightly fitting glove would catch on a piece of turning wood and cause an accident would depend also on factors including the surface roughness and frictional properties of even a smooth surface, which can change quickly. (for example, while applying friction polish)
Tight cloth gloves would help prevent the protrusion case but not the surface case. Unless the bundle comprising the threads across the entire width of the glove was weak enough to break, the hazard still exists with tightly fitting gloves. (Gloves made of paper towel material that would tear away would be much safer but I've never seen them.)
There is a basic flaw with anecdotal "evidence" of a lifetime of method proving something safe - just one contrary case proves it wrong. Any one person may use gloves without an accident for his entire life, a flat worker might use table saws for a lifetime without guards, and three generations of farmers in one family might jump up and down on the post hole digger. The next guy might have a different experience.
Each person must evaluate the known or perceived risks and make his own decision. I personally take many risks in life but I am not willing to take that particular risk with my hands. Chopin and Liszt would certainly suffer on my piano with a few missing fingers on either hand. Of course, I probably wouldn't type such long and wordy messages then.
Re: Turning glove
Re: There is ONE simple rule
Russ Fairfield
>Keep your fingers behind the tool rest when the wood is spinning.
It won't make any difference whether you are wearing or not wearing a glove if your finger gets caught between the wood and the toolrest.
Re: Turning glove
JimQ
>I used to drive for the Electronics Division of North American Van Lines. They had an OSHA required rule that rings were not to be worn while handling freight. A lot of the drivers just ignored it or said, "It's my wedding ring. It stays on." I personally know of a driver who had a nail head on a packing crate catch on his wedding ring as it tipped over. He lost his finger at the third joint. No place to put the ring now.
Is it going to happen to evryone? No. Can it happen to anyone? Hell yes! Are you going to be killed by lightning swinging a golf club when a thunder storm is nearby? Probably not, but how many are killed every year because they felt the risk was worthwhile.
Is it a worthwhile risk for me? No. I already have damage on my right hand from other woodworking.
JimQ
Re: Turning glove
faceplate vs spindle
TDaniel
>JK, when using the tailstock the likelihood of something wrapping around the work is much greater than when turning bowls on a faceplate; therefore, when doing spindle work I would not recommend gloves....especially cloth ones. On the other hand, when working without the tailstock there is virtually no chance of anything wrapping around the piece while turning the outside. I think when roughing the outside of a piece with bark it is safer and more comfortable with a tight fitting pair of leather gloves. I prefer the thin, soft gloves rather than the heavy and bulky work gloves with cloth cuffs. I never use the Jersey type work gloves or the carving gloves.
Re: Turning glove
>The argument that you have all your fingers is spurious. Those who have not been so lucky are much less likely to be typing a response to this discussion, especially not on a turning forum. If they are alive, if they can still type, they are not likely to still be turning, and would thus have no reason to be here.
