Powermatic 3520 packaging?
Craig Daymon
>OK, the 3520 is in the basement. Even in parts, that was an effort to get down there. I THINK the bed weighs more than the headstock, but it's close.
I had to get a truck and pick it up at a freight company. My question is this, why does Powermatic package an item that is essentially top heavy fully assembled? Sure, if I had a garage shop or separate shop dropping the lathe in place, wiring and going to work would be nice, but if I'm buying a beast like this is it really that big a deal to put the parts together? There really isn't that much assembly, even if the parts are heavy and somewhat awkward to handle. The box dimensions were 26" wide, 54"(+/-) long and 60" high. Does OneWay ship this way? (Though I think the OneWay center of gravity might be lower.)
(Yes, it fell over in the truck, less than 5 minutes out of the freight company. Seems OK, but I won't know for sure until I can get electric run to power it up.)
-Craig (fingers crossed)
Re: Powermatic 3520 packaging?
My guess
Jay in TX
>Craig,
My guess is first; shipping you (and I) a fully functioning tested product. Seems reasonable that they might have a test unit to put the wires in and power it up before it goes out the door. Secondly (really First but I was trying to be optimistic), packaging costs more money (Personnel, Materials, and Time) when dealing with multiple parts. As it is, these things are probably built on a line with bins holding all the small bits. At the end they know they have a quality product before they cover it with that big cardboard box.
Re: My guess
David
>Not that this is really worth anything, but I used to work at a place that had a contract to manufacture two hundred something of giant cabinets with radio equipment in them. They were 80+ inches tall, and maybe 24" x 24". 900 pounds of look out below. They were put on pallets that were measured out wide to reduce the risk of tipping - and we had huge arguments with the customer about that because they wanted to cram more of them on trucks.
The moral of the story is - I'm sure they wanted you to have a fully functional unit, without the liability of an end user assembling something that spins at the rate these machines spin. At the same time, a wide pallet wouldn't would be a good idea for them, and pretty inexpensive "insurance".
Hope you get that baby up and running without further incident!!!
David B.
Jerry from Lapel In.
>The new 3520B come with the legs of and it's not top heavy.
ken chase
>Craig:
I bought mine from Amazon. No tax and the delivery man dollied into my shop, unpackaged it and put it in place.
Brian McKearney
Brian McKearney
>Yes, Oneways also arrive fully assembled. I believe that the reason behind this is that the intent is that you should receive a fully working product that is factory assembled and aligned. This way, they can at least make a statement about the product as it left their door.
I can sympathize with you regarding taking it apart and getting into a basement. I am fortunate enough to have a walk-in basement, and the freight driver helped me to drive my lathe right into my shop - couldn't have asked for more!
Brian
Gary in Zirconia, NC
>I didn't have a problem with my 3520a being assembled. I just removed the head and tail stocks and put it in my shop by myself in about an hour and had it turning. I'm glad I didn't have to assemble it.
>My friend and I picked up two of them. We tied them down big time, one in his trailer and one in my truck. Ididn't think I would be able to get back up the mountain. We had to disassemble mine to get it in the shop. The bed is 250lbs and the headstock 157. We were able to unload my friends by simpley removing the headstock and tailstock.
Dick Hines
Dick Hines
>I work for Avaya Inc. and the telephone switchs are shipped bolted tp a pallet. They are almost 6 feet tall and about 30 inches square and all the packing they have is a big plastic bag and a big box.
Any thing as big as a telephone switch,lathe or biger things arn not packed like small stuff. Most come with a little red thing that looks like a level and you can tell if it has been tiped or droped. In the 40 years in the telephone business I have only seen a couple of switches that had to be sent baxk because of damage.
Re: My guess
JimQ
>15 years ago I was one of those drivers who hauled those telephone switches and other computer control cabinets. I was very glad to have those oversize pallets, because most of those 6' tall cabinets had their power supply mounted at the very top so the heat could rise up and out. That put 35% of the component weight in the top 12" of the cabinet.
I've even delivered X-ray equipment to hospitals. Try moving a 2200# X-ray table that's 7' long by 3 1/2' wide with a base about 2x3' in the middle and no wheels. NOT FUN!
JimQ
Chris K in MD
>Craig,
I had the same problem back in march. I was nto as fortunate the fall smashed the motor control box so I refused the shipment. The second unit arrived saftly! Enjoy its a GREAT lathe!
Chris
D_Wimmer
>Mine could not be delivered on the 48' trailer it came on because it was impossible to turn it around on the mountain road I live on.
We loaded it off to my pickup with forklift at a nearby business.
I used straps to brace it by cutting a 6" hole on either side of the box and attaching them to the lathe bed to steady it on the mountain roads. Pushed it off the tailgate and drug it across the shop, then removed the pallet.
