Watco Danish Oil
Watco Danish Oil
Watco Danish Oil
David
>I picked up a can of the Natural finish Watco not too long ago, and I'm having some difficulty with it. I'm following (or at least I think I am) the instructions, in that I use a rag to wipe it on, and I don't stop until the whole piece is glistening, then let it sit for 30 minutes. At the end of 30 minutes, there is a small pool in the bottom of the bowl, but the rest is dry. I re-apply more, again until the whole bowl is glistening, then let it site for 15 minutes, then wipe the whole thing off. 24 hours later, repeat.
I've been doing this two, three, four times on a given piece (one white birch, the other some random hardwood from the local pile), and the result is an incredibly dull finish. Like dull to the point where the bare bowl gave off more shimmer. I don't expect a high gloss here, but the wood looks so dead it is incredible.
I'm wondering if the idea is to immerse the bowl for a period of time,(I hope not because I would need a gallon of the stuff), or if it just takes a million coats for the wood to suck it in.
Thanks -
David B.
Re: Watco Danish Oil
JKJ in East TN
>I haven't tried it with birch, but some woods do need more coats than others. I use it on cherry, maple, and others. I generally recoat fdor about a week. The final finish requires buffing to get a gloss. I use the Beale buffing wheels.
Brian Hahn in SW Wisconsin
>Danish Oil (Watco and others) is not a surface / top coat finish. So don't expect much shine from it.
Normally I sand as I'm applying it, using a finer grit wet/dry paper for each successive coat. That improves the wood's surface smoothness and shine to some extent. The sanding "dust" slurry will also fill the pores. That's good for most cases, but not all. Usually I only need three coats, then the wood stops accepting the oil (the filled pores are probably a factor here).
After the oil has cured (a week or so), I'll wax it to get a nice sheen. The Beall buffing system also does a very nice job.
David
>Thanks for the tips - I had a feeling this would result in buffing.
David B.
Don Henthorn
>The thing I did not read in your method of application is the thorough wiping of the finish after the fifteen or twenty minutes of initial soaking. I would wipe the finish thoroughly and then let dry for a day before putting on another coat. Use the same procedure for each succeeding coat. It is not true that you can't build up a sheen with Watco. It just takes many more coats because the amount of resin you apply with each coat is very small. I dislike Watco because although in the short run you can get a nice looking finish, after six months or more the finish begins looking very dry and you will need to apply another coat. I remember Sam Maloof who used his own mixture similar to watco used to go to his clients home to renew thw finish that needed pepping up on his furniture.
Larry
>Make sure that you are sanding to a fine enough grit. You won't get a shine until you are getting down pretty fine (without a lot of coats). Try this - sand to 320 apply Watco. Instead of letting it sit 30 min, keep applying it to all spots that dry. once the spots no longer dry, wipe it off repeatedly till all bleeding stops. Set it some place that's not humid for a week. Now go back to 240 and sand down to 400. Repeat the application & wait a week. Finally start at 320 and sand down to 600 or even 1200 & re-apply.
One Note: I would avoid wet sanding as it can muddy and blur the grain contrast on some wood - wood that is porous (like black walnut) can be especially bad.
My experience is like Don's
Rob Overton,Houston, Texas
Re: My experience is like Don's
David
>Thanks again -
I guess I left the wipe off step out of my earlier post, but after the fifteen minutes I do wipe it down. Then 24 hours later, I sand with 600, then repeat the entire process. I'm up to 3 coats (might be 4, I lost count) on the one I'm working now, and there are a couple of areas showing signs of saturation, but only a couple. I'm starting to think that my Minwax Antique Oil Finish is my personal favorite - it takes several coats, but eventually you get something for your effort. Or tung oil.
David B.
Jeff
>I have a question that would go along with this one. I'm finishing a piece with Watco's Teak Oil, and if I'm not mistaking it has the same instructions as the Danish Oil, Is there anything wrong with applying the oil 2 or 3 times (until the wood, for the most part, stays shiney) letting it dry for 72 hrs (like the can says) then topcoating it with tung oil? or should I let it dry longer? keep applying the oil until the whole thing stays shiney?
David
>I think that's basically ok. In fact, I got sick of the watco on the piece I'm working, and just added two coats of tung oil, then waxed, I'm DONE.
But - you might want to start a new thread. This one is pretty old, and I doubt anybody will think to look way down the page to here...
David B.
