trowing tops
trowing tops
trowing tops
RevDoug
>I remember a post (or posts), probably last winter, about throwing tops. I did a search and did not come up with a single post or pic. If you remember when it was, or if it was you, I'm in need of some dimensions.
TIA
Turn 'em round,
Re: trowing tops
Re: trowing tops
David
>Used to play with them as a kid, part of the seasonal games and events we did while growing up. Turned a few, and used nails for points. Have turned some recently for a woman in Illinois, I think and used the plastic points from this site:
http://www.toycrafter.com/Archives/Index.htm
Don't know if there is a standard size or shape, but you can get a good idea from the photos on the site indicated above.
Have made a few for decoration, but don't know if I can find the photos.
Re: trowing tops
Re: trowing tops
>JKJ is a master top maker. Hopefully he will chime in.
Re: trowing tops
THROWING TOPS (wish we had spell check)
RevDoug
Re: trowing tops
Re:There is a good spell check... *LINK*
Joe Herrmann
>There is a great spell check that you can download for free that allows you to check the spelling on all posts on various forums and other lists You can get it at the link below. Works great!!
http://www.iespell.com/download.php
Re: trowing tops
Also
Dan Donaldson
>If you use Firefox, there is an extension that gives spellcheck on almost anything with just a right mouse click.
Re: trowing tops
Re: trowing tops *LINK*
JKJ in East TN
>A couple of years ago I found some drawings and dimensions somewhere on the web. They may be somewhere in the link below but if not, I can measure some that I made at the time. I made the tips on my lathe from some nylon rod I had around.
Spinning tops
Re: trowing tops
Re: THROWING TOPS (wish we had spell check)
JimQ
>How do you know he isn't looking for trowing tops instead of throwing tops? Rev doesn't have a spelling problem, he has a typing problem, or maybe he has a code id da node. Right Rev?
JimQ
Re: trowing tops
Re: throwing tops
RevDoug
>JKJ, that is an interesting group of sites, but none has anything to do with dimensions. Really all I'm looking for is if there is a prescribed set of ratios that make for an easy to throw top that will spin well, even for the novice top thrower. Does such a critter exist?
Turn 'em round,
Re: trowing tops
Re: trowing tops
Jorge Castaneda~Downeast Maine
>Doug,
I grew up playing with tops, it was one of the seasonal fads when we were in grammar school, the size of the top depends on the hand that is going to play with it, in general the upper part is nearly spherical and then an arch down to nearly twice the diameter, again, play with proportions and whatever please your eye and hand is good. For the tip we used steel wood screws, once you drive it home, cut the head with a hack saw and with a file make the tip round.
We had basically two styles, the regular, with a small head and you wrap string way up and trow it from over your head, I used to trow it upside downand when you pull the string it rights up.
The other style, a flat wide head and you only wrap string about half way and then trow it under arm and pull on the string, girls used this more often, in this case the top is right side up, both styles work, your aim is to create a top that goes to sleep for the longest time and that lets you pick it up in the palm of your hand and keps on going, we had several games, but that is another story
Hope this helps, Have fun
Jorge
ps, leave enough wood around the screw, so it is strong and don't brake easy, also the screw has to be rather long inside the body of the top so it does not have the tendency to bend and brake the wood.
The harder the wood, the better. They were usually decorated with burn bands, just put a piece of resinous wood to it while it is spinning on the lathe.
Re: trowing tops
Re: throwing tops
>Doug,
See my post above, the proportions are very flexible, the condition is tah it must fit the hand that is going to play with it.
You cannot have a set of proportions, each hand is different.
Jorge
Re: trowing tops
Re: throwing tops
David
>Oddly enough, the demo at my turning club last night was on throwing tops. The fellow who gave the demo makes these for people to use in competition - he turns them, and his daughter in law paints them, and I might add does a mighty fine job of it.
Here's the website of our turning group, you'll want to look at "Past Events", and then you'll see a reference to the "Turners 2" meeting. There will be photos of the demo (maybe not yet!), with some explanations.
http://www.wnywoodturners.com/
Here's what I remember:
He used hardwoods - mostly cherry. He starts with a blank that is 2.5" x 5". He's got a special faceplate chuck which screws onto his lathe like any other chuck, but this thing has like eight screws in it to hold that little bitty wood. He's tried typical chucks, but prefers this method because you really need to hold it tight for the end product to run true.
He uses a sixteen penny nail and a #6 washer for the point. He uses a bolt cutter to cut the nail at a height of low, medium, or high, and has a jig to give him consistency in those three heights (depends which a customer preferes). He's got another jig that allows him to position the #6 washer onto the remaining nail such that it is perpendicular, which is more or less a pencil holder. Once positioned, he removes the washer/nail from the jig, and solders them together. I didn't explain that well, hope you get it. Basically, the cut end of the nail will go into the top, and will stop at the depth the washer will dictate. The point sticks out low, medium, or high.
Now the blank is on the lathe, and he starts a small hole in the center with his skew or spindle gouge, I forget, just enough to show where center is. He then drills a hole for the nail (using vice grips and the correct size drill bit, and carefully allows it to "find center" based on the pilot hole of the previous sentence. The nail is banged hom in the blank, I believe a friction fit, and now he is ready to turn.
He uses a skew as his primary tool, and finishes with a spindle gouge and then a parting tool. After rounding the blank with his skew, the 5" of wood is divided up. He cuts a line roughly halfway, so there is 2.5" on either side of the blank. From his orientation, on the left side is the faceplate with eight screws consuming part of that 2.5", and on the other side is a cylinder with a nail sticking out the bottom. He uses a flat file to true up the point of the nail, and sands it for burrs. sharpness/roundness of the tip is dependent on the surface it will be used on - tile floor would need a sharp point, concrete is going to dull the point anyway, you would leave that a little round.
He shapes the top (the right hand 2.5"). Somebody asked if they needed to be a particular shape, he said no, they didn't all have to look like hot air balloons. (I thought that was pretty funny, and it gave me an idea for a decorative lathe creating, guess what that would be). He gives it that shape with the skew, and also cuts in about four lines, plus a ridge near the botton to hold the string (you'll have to see pictures of that, but the lines help hold the string in place, and the ridge at the bottom keep the string from falling off when you wind it up. All the lines were burned in using guitar wire) The string he uses is basically chalk-line string, and the rule of thumb for length is your armspan, or roughly five feet. Shaping is finished with a spindle gouge (his goal is to learn how to do the whole thing with a skew!). The nail end of the piece is reduced (in a nice shape) to the same diameter as the washer. Pretty delicate stuff as you approach the washer.
He sands it to about 400 grit, then for a natural finish, he uses CA glue, which he applies while the lathe is spinning (at very low speed, and with all the people in front of the lathe getting out of the way once they realize what the stuff is). CA glue gives a hard finish that looks good, dries fast, and is durable. Very clever I thought.
He parts off the top, uses his skew to clean up the top, tada, you've got a top. And you still have 2.5 inches of cylinder spinning on the lathe. So, what he does is use about an inch of that to make a base for the top - so he drills another hold, creates a decorative base, and cuts that off the blank, leaving a little bit of wood behind on the lathe. Now the top has a stand to live in when not in use, and the point isn't at risk of getting dinged up or dinging somebody. He had several tops on display that his daughter in law had painted using normal old everyday model paint, finished with spray lacquer. I'm sure pictures will be posted on the turning website, and they really looked sharp.
Anyway, that's as well as I can remember it. The whole thing was very clever and looked like a lot of fun to try.
The end.
Re: trowing tops
Re: throwing tops
JKJ in East TN
>>...that is an interesting group of sites,
I wasn't sure and didn't have time to check, that's why I said the info may be somewhere there. I did find a site with good dimensions. I remember finding one with either dimensions or a pattern - I made a pattern and used it at the lathe. Perhaps you can search with google. Another thing to do is go buy one at the toy store and use it as a guide.
I tried making several variations and all worked well except for one.
Re: trowing tops
Re: throwing tops *LINK*
JimQ
>Here is a site I found on another Forum.
JimQ
Top dimensions
Re: trowing tops
Re: throwing tops
JKJ in East TN
>JimQ,
Great! That's exactly the link I used before. In fact, today I looked under my bowl of throwing tops and found where I had printed that same page for future reference, then forgot all about it. Sigh.
