Sandpaper *LINK*
Sandpaper *LINK*
Brian McKearney
Sandpaper *LINK*
Brian McKearney
>I recall seeing various posts over the past year or two regarding sandpaper purchases, and I think someone mentioned that they purchase sandpaper from Industrial Abrasives. Looking at their web site, you can purchase sheets (1 meter X 1 yard) of Rhynogrip Hook & Loop sandpaper for $15.75. At that price, it would appear that one could cut this into approximately 300+ 2" sanding discs (if my math and metric conversion is correct). As compared to some place like Packard (300 2" Hi-Per Gold discs for approximately $60+).
The latest issue of Woodturning magazine (September 2005 issue - from England) has a reader tip that describes making a punch from a 2" hole saw (grind off the teeth and then sharpen the edge).
Does anyone else purchase sanding discs this way, or do you purchase pre-cut discs someplace? Is the sandpaper at Industrial Abrasives any good? If you do purchase your sandpaper in sheets, do you use a punch to cut round discs, or do you just cut it into 2" squares and use it that way?
Brian
Industrial Abrasives - Sandpaper Sheets
Re: Sandpaper *LINK*
Re: Sandpaper
Norm Smith in Nova Scotia
>Hi Brian
I purchase 4.5" X 9" sheets of hook and loop sand paper and cut my own sanding discs in both 2" and 3". I have been using a 2" and a 3" hole saw with the teeth ground off and sharpened for years. It is an easy system to use and saves a lot of bucks.
Good luck,
Norm
Brian McKearney
Re: Sandpaper
Brian McKearney
>Thanks for the feedback - sounds like the way to go. Where do you purchase your 4.5" x 9" sandpaper? Is it available at someplace like Home Depot or is it a mail order purchase, if you don't mind my asking? The paper from Industrial Abrasives seems very reasonable, but I think that 300 discs of each grit would last me for 10+ years!
Brian
AnthonyY
>Figure your cost per disc, then add labor and compare with these prices. These are the best discs I've found in ten years.
sanding discs
Re: Sandpaper
George Van in WI
>Mark Kauder got me cutting the abrasive on the bandsaw, works great and the square corners work like a wave disk. I only use this blade for sandpaper, it was dull from use so I am out nothing. I am very satisfied with the paper I have received from Industrial Abrasives.
Re: 3 cents per disc, shop made.
Al Crandall- NE of Indy
>I buy my 5" discs from a supplier I first bought from on ebay. I pay around $11 or $12 for a box of 100, from which I can cut 400 2" discs. I use the sharpened hole saw in the drill press with a foot activated on-off switch. I position the disc on the wood "die" and apply pressure with the press turned off. Then I tap the switch rapidly twice with my toe to turn it on and off. When the quill is retracted a finished disc pops out. I sharpen the inside of the hole saw so the taper makes it more or less self cleaning and I seldom have to poke a disc out after cutting it. I have also ocacasionally used a scalpel or a box cutter to quarter the discs. I can't see any benefit to having the three corners hanging outside the main disc like the wave discs advertise, but then there seems to be no downside also.
Link has no company information...
David
>Prices on the PDF link are very good. I did a search on Google, and came up with CAPCO, a company in Minnesota. Is this the correct one?
Re: Sandpaper
Bud Gabaree
>I agree with Mark. I've been using the Rhino paper for about a year now. I bought the big sheets and cut them on the bandsaw. It takes me about an hour to cut 100 squares of each grit, 60 thru 600, so I consider the labor negligible. The best part? After cutting 100 squares I still have enough paper for more than 200 more!
I don't see how it gets cheaper than this. And the quality is superb. For the first time, it doesn't bother me to not reuse discs for more than one sanding session.
My 2 cents, Bud
Re: Link has no company information...  *LINK*
AnthonyY
sandpaper
Thanks for the follow-up, Tony!
David
Re: Sandpaper
Dominic Greco in Richboro, PA
Brian,
Like many others, I credit Mark Kauder with turning me onto Industrial Abrasives. I bought an assortment of 1 yd x 1 m rolls from them 2 years ago and have yet to use them up.
However, rather than cutting them up with a bandsaw, I use a razor knife and straight edge. The 2" squares act just like wave discs.
I also had a friend of mine make me a 2" punch. I use this for those instances where I want to sand close into a corner, or right up against a bead/cove.
See ya around,
Dominic
Re: Sandpaper
Mark Kauder, Phenix City, AL
>Just for the Record - Russ Fairfield is the one that turned me on to Industrial Abrasives 2-3 years ago.
I am not even sure that I am the one that came up with using the bandsaw to cut the disks, but I did publish it.
Russ is also the source telling me that square "disks" work the same as the wavey edges.
All hail Russ Fairfield - how far behind would we all be w/o Russ.
Thanks, Russ
Mark
Re: Thanks for the follow-up, Tony!
AnthonyY
>You're welcome, who's Tony!!
David
>Oops, Anthony. Sorry if I got too familiar...
