We value your privacy.
>I need to change the belt on my Nova 3000. At first glance, it looks like I will have to remove the motor to provide space to slip on the new belt. I added a handwheel, and don't remember how I installed it. Tried a pipe wrench, but after some movement in each direction, it seems to be stuck on there. If I can't remove the handwheel, it looks like I won't be able to remove the motor. Any one done this before?
>Remove the (stupid IMNSHO) red dust cover. Slip the belt all the way in in over the headstock pulley. You can then (with the motor pulley in the loose position) slip the belt over the smallest of the motor steps. I never put the dust cover back. It serves no structural purpose, nor does it keep dust out - you don't get dust or chips in there with it off. With it off it is much easier to change belt position.
>I doubt if the dust cover can be removed with the handwheel in place. Is there any way to work it around past the handwheel and through the hole in the the dust cover through so careful twisting? I would not run my Nova 3K without the dust cover. I have a thing about exposed pulleys and belts.
I don't have a handwheel so I don't know why it is stuck. Is there possibly a grub screw?
>Tin snips would do it (as long as it was a permanent removal. As far as worrying about the exposed pulleys & belts - you would have to intentionally work at getting your fingers caught.
