We value your privacy.
>Here is a series of turnings I did recently. There was no waist blocks used. Piece no.3 was turned from a triangle, piece no.2 was turned from a long wedge shaped blank, and piece no.1 was turned from a rectancle blank mounted offset. All comments welcome.
>Superb job...! And you still have all your fingers? Assuming no major injuries occurred, a little tutorial on how to turn these beauties without shedding blood would be very cool.
>Hi Vicmarc fan, an easy way to make these without a glue block is to start between centers, then make a groove with a parting tool on each end. the groove is wide enough for the chuck to fit into. Insert one end into the chuck, holding the piece with the groove, and turn. Flip over the blank and hold in the chuck with the other groove, removing all signs of how the other end was held, as it is turned away. Doing it this way eliminates the need for glue blocks.
>You are right Keith. A very good way to do it. In my initial post I was refering to a tecnique where waist blocks are glued on and then the turning is done in the round. The wasit wood is then cut off again to leave the shape desired. This is not however, how I did these pieces. The this piece I used a face plate at the place where the opening to the bowl portion is. Using a spindle extention, to gain room on the back side, I shape both sides to the finished shape. I then reversed it into a vaccume chuck and hollowed out the bowl. very eazy, and usefull for unbalanced pieces. Here is a pic of how "one" started.
>Wow, I've seen plenty with three or four winged "legs" like the first, but two, and especially one - unique. I applaud your creativity. I want some of the vitamins you AND Mike Schwing must be taking.
