We value your privacy.
I just bought one of those cheapo drill assisted lathe on ebay. Just to get my feet wet.
I want to make clock finials. I have a few old clocks and would like to make some finials to match what should be there.
So far I know that they should be made of cherry wood. I need the stock wood to be at least 4 or 5 inches in length as the finials I am making are aprox 3 1/2 or less. And they have to be bigger than pen stock for width.
I experimented so far with lathe and some wood chisels. Was careful to wear eye goggles. I bought some pressed wood to experiment with.
It looks like I may need to buy a duplicator or really take some serious time to make the finials exact same demensions.
Is there a simpler method than cut/measure, cut/measure, cut/measure to make duplicates? Maybe a work arround or jerry rig that might make acceptable copy?
If things go well I may invest money later for this part of my hobby.
Just testing the waters.
I see a duplicator sells on ebay for $100 aprox. How does this thing attach and guide my wood chisel???
Too bad you were sucked in the black hole of woodturning. Your family will miss you. Your new home will be your shop. All of your savings and future income will be directed towards the endless acquisition of new tools. Sigh... [g]
I don't think you should spend money on a duplicator, at least not right now. In fact, I wouldn't even try to duplicate anything at all at first. Instead, spend time learning the basics and become expert with two tools: the spindle gouge and the skew chisel. It won't matter what you make and if the size is correct as you perfect the techniques.
If possible, find a turner to help you get started, take a class, watch a video, and/or purchase some books. Richard Raffan and Mike Darlow both have excellent books with introductory info and instruction that will take you from "what's a lathe" to "wow, look at this!"
Cherry is a great wood for practice, as is walnut, maple, or nearly anything. Except pressed wood. If that's what I think it is, I've never heard of anyone turning it and I'm not sure I'd want to.
As for duplication, do the finials need to be identical to the 1/2 millimeter? Ususally that is not necessary. You can get very close by eye with the aid of some type of pattern. Mount a pattern drawn on cardboard or thin plywood where you can see and refer to it just behind the work. Mount the object you want to duplicate just behind the work. Use a "story stick" with lines, notches for a pencil, or wire brads to make marks on the turned cylinder. Cut a template from cardboard and hold it up against the turning. The books cover all these techniques. You may find that duplicating finials by hand is not as difficult as it now seems!
Also remember, minor differences in even identical pieces can provide character and give things that hand-crafted look. Even the pawns in a chess set might look too mechanically cold and mass-produced (i.e., read "cheap") if they are too perfect.
Welcome! You said you were using "wood chisels". I do hope you meant turning tools...gouges skew chisels, etc and not bench chisels! Save the $100 you are thinking about using for a duplicator and put it towards a Jet Mini (or other good Mini) and some decent turning tools and maybe some books and videos. With a little practice, you will probably be able to duplicate the finials close enough that any differences will not be detected.
>When you say pressed wood, if you mean the pressure-treated stuff you use outside the house, I'm pretty sure you don't want to work with that on the lathe.
Uh ohh. So I am going to get hooked on turning. Got hooked on clocks previous. Family is gonna start hating me.
Uh, yeah I just bought the pressed wood as practice. Just wanted to start turning. Less than $2. I wanted to do it NOW!!!!
Holding up cardboard cut-out or drawing to compare sizes sound like great ideal. Thinking maybe one of those prong like guages to measure thickness.
I knew there had to be a simpler way!!
Also like the explanation of things being too perfect hence "cheap". I know exactly what you mean. Imperfections adding characture and precieved personalized warmth.
Ok, so I am going to skip the duplicator. (For now) Also I need regular wood turning chizels. (Although the square wood chisels worked, but would have been nicer to have smaller rounded ones.)
You have to understand I'm working with small budget here. So a little jerry rigging or make due method info is apreciated.
Another thing I have been wondering. I see the plate is attachment that makes bowls.
Is it possible to simply mount drill motor somehow in vice. Then attach plate in drill chuck and carve out a bowl that way.
My lathe uses a drill motor attachment and it works adaquatley. Just wondering if anybody has done it this way. Don't see why it would not work for carving inside of bowl out.
Maybe there is a plate that would work with my lathe? Somehow I think not, because it's sorta make shift.
Next to work on getting the cherry wood. For my clock finials. Got to check out local wood shop first. Then mabye ebay.
Just to be clear, when I said "too perfect" I guess I really meant too identical or too perfectly alike. I am a strong proponent of the pursuit of perfection and excellence in the craft, i.e., clean flowing curves, no unintended tool marks, crisp detail, perfect finish, etc.
Having the correct tools is vitally important. Although you can scratch out something with even an old screwdriver or a nail held in visegrips, there are plenty of easier ways to induce self-inflicted suffering. The tools do not have to be expensive but to be effective they do have to be shaped correctly and extremely sharp.
I for one am having difficulty visualizing the type of lathe you are working with. I don't know what a drill-assisted lathe is or how you would mount any part of it in a vise. What is the "plate" you mentioned? Is it a "faceplate"? It is hard to advise how to proceed.
It seems from your questions you could use a basic introduction to woodturning. While you are locating a person to help, try some of these links. They will describe the common tools and basic equipment needed. And just learning the terminology will help you communicate.
Also, cherry wood the size you need for small finials should be easy to find and very inexpensive. There are several people here who sell wood, mostly as a hobby (and because they love wood!) If you tell the area where you live, someone in your area might gladly give you some small pieces for practice. Depending on where you live and how hard you look, wood can be free or nearly free. Around here, cherry is so plentiful it's used for firewood - split up a few firewood chunks and let them dry for a while and you could make hundreds of clock finials.
