We value your privacy.
I would like to get started in wood turning. A friend of mine for many years told me to buy the best lathe I can afford. He has bought 3 lathes over the last few years and has outgrown all of them. His last purchase is a Jet and he is not happy with it. I can't seem to find a good comparison/evaluation of lathes.
My question -- I prefer good quality equipment ... is there a lathe that has the great value, something for a serious non professional to buy. I like the Oneway 2036, but they are expensive, although, if Oneway is a world ahead of all the other lathes, I guess I would just have to plan for a future purchase.
My preference would be something under $2,000. And my interest is to turn bowls and vases. I have received some good feedback and recommendations for the Teknatool International Nova DVR.
I will pass on some advice I got here on this very forum a few months back, in light of your comment that you are interested mainly in bowls and vases. Check out the Vega 2600 bowl lathe. It is a little more money than what you say you would like to spend, but it is going to be a lot more lathe than the Nova DVR. I wrote several posts on it in the past few months. If you search on Vega you will get them all, including pictures. There are several other Vega owners here as well who may speak up.
The lathe takes up very little room, about the same as a mini on a stand, but it weighs 550 lbs, will spin a 26" bowl, and will do spindle work up to 17" long. It has a 2 HP 3 phase motor (only needs single phase 220v power) and a very luxurious variable speed control. Retail price right now is $2595 if I recall correctly.
There are a lot of lathes on the market, so whatever it is you think you might like, it is a good idea to try and get some time on the ones you are considering. There is nothing like buying an expensive piece of equipment only to find out it is not what you thought.
>I have the older verison of the Nova (Model 3000 with an extra bed section driven by a VS 1.5 HP DC motor). It is a great valued- priced, mid-size lathe. It is not a 20" Oneway in swing, heft, or price so if this is what you have in mind, then it is not for you. However, the Nova is an excellent lathe and will serve you well for many, many years.
I also have the Vega 2400 and love it for bowls and vases. I still turn most of my small stuff and all of my spindle work on the Nova but all of the big stuff and most hollowing is done on the Vega. I am not as certain as Bill that it serves well as a "first lathe", especially if you will be experimenting with all types of turning (pens, bottle stoppers, ornaments, boxes, bowls, platters, vases, etc). It is designed as a BIG lathe despite its dimunitive footprint, therefore some of the accessories you will want to buy (and you WILL want to buy them) may not be designed for this lathe. The 1-1/4" tool post is one example. However I wish to quickly reiterate Bill's comments that the Vega is a superlative lathe that you will not outgrow.
I also have a Jet mini lathe that I rarely use and is mostly a dust reservior. Although I have seen some beautiful work come off of mini-lathes, I find that everyone that gets seriously into turning always upgrades. It great for those that wish to try turning as a new hobby or just turn small stuff like the occasional furniture part, pens, tops, etc.
I have never driven one but you may wish to look at the 20" Powermatic. It is priced the same as the Vega but will allow you to turn longer spindles and the move the head to the end of the bed for use as a short bed lathe for hollowing. If you have access to "big wood", then the Vega's swing is the better option. Also the Powermatic's footprint is substantial and will swallow up a lage piece of your shops real estate.
>For once I've clicked on a * NM * response on purpose ! ;-)
For every 5 turners, you'll get 6 opinions about this sort of thing. I'd say seek out a turning club nearby, and get to know the people there. Try to get as much hands-on, or one-on-one exposure to different lathes and different turners as you can. When it becomes clear who are the most knowledgeable turners, seek their advice, and weigh that with your experience on different machines. You can also learn a lot at a turning symposium; the one in Albany is a very good one.
That said, there's no substitute for high quality that lasts, accurate machining, and a good rule of thumb is that when all other factors are equal, heavier is almost always better.
My first lathe was a ShopSmith, and my second a Jet 1236. While the Jet does have a 1" spindle (instead of 5/8"), and is more stable on heavier pieces of wood (with 8 cinder blocks between its legs!), as soon as I can afford to do so, I'm getting a top quality lathe. I also own a roughly 100 year-old pattern makers and metal spinning lathe which is MUCH better made than the Jet.
I'd suggest that once you know a thing or three about your needs, a rugged, older lathe is still a very good value. If I find a good deal on an old Powermatic 90, or a heavy-duty machine like a Blount or Oliver, I'd be very happy with that as a spindle/small diameter lathe. Old pattern makers lathes are also a good bet. If you get into bowls in a big way, a short-bed lathe, or dedicated bowl lathe will not only give you large diameter capacity, but the ability to stand in front of the work, instead of leaning over the bed -- a huge advantage of bowl lathes like the VB-36, or Vega 2600. Lathes with sliding headstocks can also be set up this way, and the larger Oneway lathes can be used with an auxiliary short bed on the outboard end.
There are a lot of choices, depending on your needs, your budget, and your patience. Best of luck...
The only way to know what`s really best for you is to spend some time turning.You can always recoup most of your money when you upgrade and sell the Jet to get what you REALLY need.
>Be sure not to overlook the accoutrements! Lathe tools, chuck, grinder, safety equipment (depending on who you are - face shield, dust equipment of some kind, etc., etc., etc.)
I will also echo an earlier comment - join a club. You will meet some terrific people who will be very giving, helpful, and who remember their own newbie trail quite well.
It is by no means a Oneway 2436 but is not in the same $$$ field either. The Oneway 2436 with the outboatd attachment offers you the best of both worlds. You can outboard to 48" but best of all it becomes a bowl lathe. Inboard 24 is very large and offers you a tailstock to turn between centers.
If you can handle the $$$ you will never be unhappy.
