We value your privacy.
>I've got a nice brand new length of white birch, but the diameter is not enough to make traditional bowl blanks. If I cut this into baloney slices and rough out some bowls, would I have any reasonable chance of preserving them to finish later if I anchor seal them after the rough out?
Might even cut one or two super-thin to see what kind of cool warping shows up.
>David I'm not sure what you mean by balony slices. If you mean take a slice off the wood with the pith in the middle like you are slicing a roll of balony then it will still probably check. I did this with a dogwood limb and placed the pieces in a plastic zip lock bag. I would turn the bag inside out every day. It took months for 1/4" thick pieces to dry but almost none of them cracked. I later cut these up into pieces for a laminated ring to use for a clock face.
>Look up Bert Marsh. He turns endgrain bowls with bark on the rim. Very thin, so checking is not an issue. You can't let wood with the pith in it dry. So turn them green and then.
I've copied those in white birch, turned green and thin with no checking problem.
you can also turn goblets and flowers endgrain from limbs (put a stem in the bottom f the vase shape.....
I have soaked end grain hollow forms in alcohol with the pith in the bottom with great success. I have also hollowed pieces with the pith running through the sides of the piece with little problem. The alcohol soaking process works for most every type and configuration of wood I have tried. There is an article on alcohol drying process in the Articles Section of Wood Central. Please email me if you need more information or can't find the article.
I just read your article. Maybe I'll give that a shot - it certainly seems to do the job, and it has become a very common practice. I've stayed away from it because the alcohol makes me nervous health-wise.
Your article actually gave me a variant idea. I could rough turn the bowls, then anchorseal the outside only, the parallel to your alcohol method being the compression idea (that it would dry faster on the inside and maybe hold shape/hopefully not crack). Hmmmmm.
>David The pieces I cut were 1/4" approximately. I put about 10 pieces in each bag. They were about 2" in diameter. I didn't do it every single day but as often as I could remember i would turn the bag inside out. I just layed a piece of wood across the opening rather than trying to seal it. After about a month I left the ends of the bag open. I did this for many months because I didn't weight them to see when they would stop losing weight. I wasn't in a hurry. A few pieces got mouldy but this actually looked good on them once I turned them. This was a spalted dogwood limb. I'll try to post a photo of the piece in the next day or so. I'll have to find the slide and scan it because that was BDP (before digital photography)
>I've also had great results turning endgrain with the pith in the middle using Dave Smith's alcohol method. I had one poplar vase develope a crack by the pith,but was able to save it by putting a wet piece of paper towel over the crack over night to swell it back together and then super glued it. I then let it finish drying and finish turned it. It worked on that piece but I have not had to try it again. Good Luck!
I've gotten away with this with very thin, translucent end-grain bowls -- ~1/8" or less. No special treatment other than turning them real thin, and placing them in paper bags. The problem area is right around the pith; if you are a daring sort of fella (with a face shield), you should have a lot of fun making a very thin, hollow foot, or even no foot...
I would not hesitate to use D. Smith's alcohol soak, either -- I've used it for some other things, but haven't applied it to the real thin stuff, since they will usually flex and not crack.
>Thanks again, John - I'm hoping to get a crack at this over the next week. I've got some travel coming up and I'm resisting getting into projects for the next day or two.
