homemade chatter tool
Peggy
>Does anyone have the instructions for making your own catter tool? I am looking to make my own to try to save some money.
Thank you.
Re: homemade chatter tool
Jennifer@Indy.USA
>Peggy,
I've had pretty good luck by taking a piece of hacksaw blade and holding it securely in a pair of Vice-Grips. You can differ the chatter pattern by the length of the blade hanging out of the Vice-Grips and by the speed of the lathe and the position in which you present it to the wood.
Jennifer
>Jennifer beat me to it. I do the same thing even though I've made a couple of chatter tools that more or less resemble the store bought variety. the vice grips are simple and effective.
David
>I thought about this the other day (hacksaw blades).
So something you might be able to do is band saw a cylindrical piece of wood in half length-wise, drill holes/screw part of a hack-saw blade on the flat of one half of the wood. The other half-round piece of the wood would comprise the balance of the "handle", but would be unattached - so you could slide it/hold it in the position you want to govern how much hack-saw blade is exposed to the piece on the lathe.
If anybody followed that....
Here you go *LINK*
CapeMayMike
>By John Lucas and John Trant...........it works.
Make a chatter tool
bernie feinerman
>I made one out of a small (6 inch) peice of threaded steel pipe from the plumbing section of a "home depot" - I bought a 10/24 thumb screw and mounted it in one end of the pipe. I then epoxied a half of a wood dowel under the thumb screw so that there would be something for the thumb screw to press upon.
I used a modified jigsaw blade for the chatter tool blade which gets held in the pipe between the thumb screw and the wood.
It is very similar to the tool cited in the link.
Use spring steel instead of bandsaw blade
John Trant (Baltimore/DC corridor)
>I now prefer the use of spring steel as the texturing blade opposed to the bandsaw blade. Bandsaw blades and jig saw blades will work, I found the spring steel less likely to bend. I have an MSC store just down the road so I bought a 6' length for cheap. It will provide a lifetime of cutters.
John
What width and thickness do you use?
Brian Hahn in SW Wisconsin
Re: What width and thickness do you use?
>I use the hacksaw blades that they use at construction sites to cut the metal 2x4's. They look like sabre saw blades. They are usually laying all over the place where they are building this type of structure. I don't remember what size they are. The best option is to simply buy one of the replacement blades from Sorby or Bonnie Klien. Most metal works in some form or another but a slightly stiff piece works best.
Width = 1/2"; thickness = ?
>I used 1/2" wide spring steel but I will have to check thickness when I get home tonight.
John
