turning green wood
turning green wood
turning green wood
>I thought I would start this to help all the newbies who want to turn but something but don't have access to dry wood. What do you turn with totally green wood. I know a lot of us rough turn bowls and then return them later or do all the alcohol soaking and such. What I'm interested in is turning projects from totally green wood start to finish.
Personally I turn thin natural edge bowls, hollow christmas ornaments with finials, and thin walled hollow vessels. Anything else? I'll probably think of more as the evening goes on.
Re: turning green wood
David
>I'm still a newbie - I've been turning since January, and have probably turned a grand total of 20 objects if that. Some day.....
(Sorry this may be slightly off topic for the post)
When I've played with green wood, I take it to a "finished" item (finished with the tools) and stuck it in a paper bag or two for a while. I've been hoping to get some interesting warps that capture the imagination, but so far I've only gotten tiny warping that looks like mistakes were made. (Two birch bowls that warped on two sides and one end-grain cedar cup that hardly warped at all.
Here's what I think I need to do to get interesting warps, and the experienced hands can tell me if I'm correct: do an end grain bowl that is fairly deep. Try to keep uniform wall thickness, but not too thin. Would you sand it? I think I've read that can retard the drying process which could be good or bad for this.
tek-Brunswick, Ohio
>You will get less warping turning the bowl end grain. The wood will warp more if the bowl is turned cross grain or faceplate orientation.
tek-Brunswick, Ohio
>Mushrooms! if they warp or crack it just adds character.
>David Get hold of some Madrone Burl or some Apple and turn it thin. If it doesn't warp enough get it wet and force it to warp.
Dave MacLuskie
>Primarily due to an utter lack of patience (even for Dave's alcohol methods) I've turned tulip lipped bowls wet. Usually 3/8" to 1/4" thick. They do warp. A knot or two has popped out.
Carole in VA
>Natural edge goblets and thin walled stuff. Try nuking them to see how they warp. Or just lop off a green limb and pratice making shavings and doing different cuts...learning and having fun at the lathe doesn't always have to result in a finished project, especially for us newbies! :)
