New WoodChat!
Question for Mini owners
Carole in VA
>How hot does your motor get? I noticed that tonight mine was fairly hot to the touch. Am I putting too much pressure on the belt when I retighten after changing speeds? Would that make the motor run hotter or is this heat normal? Granted it is a hot day, but I have never noticed it before.
Re: Question for Mini owners
Bruce Wiseman
>Hi,
My Jet mini gets pretty warm as well. One thing is to be sure the air vents on the motor are not full of shavings, etc. I occasionally blow some compressed air in there and vac it out.
Bruce
Fog Tanner
>One of the guys in our club had that problem and found a solution. He made a heat sheild out of some sheet metal and mounted it above the motor. It keeps the motor from getting covered in shavings and runs much cooler. I have used it before and after the change and can tell a difference in how hot the motor gets.
The Vic 100, which the Jet mini was copied from, has the motor in a sheet metal stand/box and completely out of the shavings. Its mounted in the same location just farther down.
Eaglesc
>I guess it's time to chip off the Ca and shavings.
My experience...
Peter Teubel
>...with Jet products is that their motors run VERY hot. Mini lathe, 1236 lathe, 20" bandsaw. All are VERY (like burn-your-hand) hot when I use(d) them. Usually a hot motor means its being overworked, but I've never had a problem or loss of power with them over years of use.
Dennis Y
>Carole, according to Jet the hot motor is normal for the mini. Dennis
David
>I use a Fische Lathe, which is extremely similar to the Mini-jet. It definitely gets a bit hot. There are heat sinks fanned out around the bottom of the motor, which I've never touched, but which I make sure are clear of chips when I'm done.
Don Henthorn
>I can't tell about my motor since I converted to a DC with controller. The motor is mounted in a box at the end of the lathe along with the converter and I have a fairly heavy duty fan blowing in the end of the box which not only cools the motor and converter but also helps keep dust and chips from entering the motor area.
oops, wrong Mini
GaryG in MD
>Carole,
This thread is getting a little stale, but as I was passing by it and saw the subject again, I couldn't help but think of something else -- so here's a pic of my Mini.
Gary
Re: oops, wrong Mini
Carole in VA
>Gary,
Does it run hot too? LOL That's a neat little vehicle.
