New WoodChat!
200+ woodworking book reviews
tape chuck
tape chuck
tape chuck
john Lucas
>This is sort of my version of what I call a tape chuck for reverse turning. This is just a photo of a made up scenario because I didn't have a bowl that might fit this size wasteblock chuck.
What I do is take a scrap of wood and mount it to a faceplate and then turn it true. Then I will turn a raised tenon or possibly a just a groove to accept the shape of the bowl. This centers it and helps hold it in place.
You may be able to turn the bottom using just the tailstock to hold every thing but sometimes the bowl slips and you always risk the possibility that the little tenon that is cut as you turn the bottom will break and the bowl goes flying.
That's why a started using blue painters masking tape. It won't leave a mark on the bowl and holds pretty well. If you need extra security put some nylon strapping tape over it. This stuff won't break but will leave glue on the bowl. If you put it over the masking tape it won't.
I started using rubber inner tube slices and they work quite well. Don Russel in Atlanta got me started using stretch wrap. This stuff won't mark the bowl and really holds.
I've never had a bowl come off. You can't take heavy cuts and I usually try to make sure that the bevel rubbing pushes the work onto the faceplate as I'm cutting. Scraping can create a lot of vibration that might loosen the bowl.
This will also work with a natural edge piece or a vase. Simply turn a small hole in the middle of the faceplate. Then turn a log so it will fit in this hole and stick out far enough to fit into your natural edge piece or into your vase. Put rubber on the tip. put the vase in place and tape it so it will be held tight. I always use the tailstock until it gets in the way. This is just plain old security.
Re: tape chuck
Re: tape chuck
David
>That is going to be an immediately handy technique for me. Thanks!
David B.
Re: tape chuck
Re: tape chuck....Brilliant!
Ruth Niles
Re: tape chuck
Re: tape chuck
Don Henthorn
>John, I have been using tape for quite a while. It is amazing how secure the work piece is if the jam chuck fits right. Never thought of suggesting the tip on the forum. I'll bet you didn't either. You probably have a lot of similar tips to offer that you kind of take for granted that others will see the obvious like you did.
Re: tape chuck
another use for tape
>I have not yet used it, but a friend of mine uses tape when turning bowls with nearly as much air as wood such that the bowl would otherwise fly apart. He turns and finishes the outside completely then wraps the outside tightly with layers of strapping tape. The strapping tape keeps the bowl from breaking apart while turning the inside.
If anyone's interested, the next time I'm over there I'll try to get a picture of one of his bowls done with this technique.
JKJ in East TN
Re: tape chuck
Re: another use for tape
Bill Crommett
>I have a beautiful piece of black willow that was comong apart if I didn't strap it. I would post a picture of it but I'm not smart enough to follow the protocol for posting pics so you will have to use your immagination.
Re: tape chuck
john Lucas
>John I saw a guy this summer who taped wire rings to the outside of bowls with large holes so that he could hollow the inside. If you have really big holes or whole sides missing the tape alone won't work because it flattens off the circle on the inside. I thought the wire frame was a great idea. This maintains the circulare shape while adding support to the wooden wings of the vessel. Can't wait to try that sometime.
Re: tape chuck
Keith Tompkins
Keith Tompkins
>I use rubber bands for almost everything...they even reduce vibration when wrapped around a thin turning such as a goblet when hollowing. They hold turnings to a waste block as well.
Re: tape chuck
Two sided tape
Ruth in So. Cal
>I use 2 sided tape on a round piece Of ply. I put it on as if it was marking out where to cut a pie. I find that I can use it a god number of times with different size bowls to work on the foot....and I also tape it but just use masking tape.
Re: tape chuck
Re: foam chuck
Arch
>Here's another 'chuck' that's in my memory bank for the time when all else fails. I've never used this dodge and I dont know if it is useful or even if it works. It's a form fitting foam mandrel for
turning the exterior of a form that is too fragile or fenestrated or irregular to be held and driven by other methods. Some might want to remember the possibility and someone here might have actual experience to share.
A tenon or block driven by a faceplate, chuck etc.
is inserted into the cavity of the piece. The tenon is a loose fit and small enough to allow a space that's filld with urethrane foam. The tenon's surface is very rough or pegs etc. produde from its surface to grip the hardened foam.
I leave it to you to solve two problems; how to center and true the fragile piece held on the foam mandrel and how to remove the foam from the bowl. I guess the same way as hollowing end grain...any way you can! :)
Arch
Re: tape chuck
>>taped wire rings to the outside of bowls.
Good idea. I guess you could use a few rings turned to fit from plywood as well.
I wonder if there is some easily removed substance that could permeate the voids and hold the entire thing together while turning. I'm thinking of something similar to a hardening foam that could be dissolved away when finished. (Doesn't TuffStuff dissolve with acetone?)
Such a substance might help protect very fragile natural edges as well.
JKJ in East TN
