Got one of these you're not using?
David
>Not a lathe tool, but a drill chuck. I'm looking for a Black & Decker drill chuck 64576-01, which is a screw-on variety (has a screw sticking out the back). Is is also marked "0 - 1/4 CAP., 3/8 - 24 THD." It is a keyed chuck.
If you've got one, chances are pretty good that you'll have to blow the dust off it to check the numbers. I don't think it will enable you to retire, but I'd be happy to buy it from you.
Mine has a bent screw, and it is a pretty complex bend to successfully straighten it. I'm having a time finding a replacement because it is too old.
Thanks -
David B.
