New WoodChat!
Tonight's chat - finishing - the basics
Sam Simpson
>Hi Y'all,
I'm posting this reminder early today, because I have meetings throughout the midday period, and I just know I will skip my midday check-in with you guys and gals.
I have noticed a few new faces on the boards and in the chats. With spring coming we are beginning to see some of the same ole' questions being asked. That's a good thing. Even us old timers need to be reminded of the basics from time to time. So let me extend an open hand to those who would like to ask some of those basic questions, but won't because you think we've all heard them already, and ask you to join me in the chat tonight. Our normal crowd of a dozen or so regulars will always welcome new faces, and I can tell from their cudgeling sometimes, that I am always ready to get into basic discussions about the use of shellac, oils, waxes and home brew mixes for finishing. Chasing down those pesky problems that rear their ugly heads at the most inopportune moments is also a favorite past-time of mine.
Come-one-come-all 9:30 est 8:30 cst Regards Sam Simpson.
Re: Tonight's chat - finishing - the basics
How can it be finishing when it hasn't started =o)
RonZ
Finished before I'm started
David
>Can't make it tonight, but I do have a question.
The ventilation in my basement shop is non-existent, and I can't afford an exhaust system (I'm also not that interested in hooking up a fan to a big hose and shoving it out the side wall of the house). This affects what I use to finish pieces - typically I use Minwax Tung Oil and Parrafin Wax. It doesn't give an incredible shine, but it is ok. Any suggestions for a non-lethal finish for an enclosed environment? Polyeurethane stinks up the whole entire house, for example, and is pretty nasty stuff I think.
Re: Finished before I'm started
Russ Fairfield
>You could sand to 1000 grit, burnish with grocery-bag paper, and then apply a coat of wax. The wax will last longer if you buff it with a natural bristle (no synthetic) scrub brush to compact the wax and give it a better shine.
If you use the Lavender wax by Talk O The Town, available from Craft Supplies, you will have a good carnauba wax and a nice lavender smell that your wife will appreciate.
Everything else has solvents or thinners that have to evaporate, and all of them stink.
>You are using a finish that has a relatively low vapor pressure already. Linseed oil (boiled) and walnut oil would be among your other choices. The oils such as these don't have hardly any vapor pressure to speak of and they polymerize by oxidation to form the finish surface. Polyurethane, shellac and others are typically "carried" in solvents, which evaporate to leave the finish. They "pack down" as the solvents evaporate.
You could try some of the water "based" finishes, I haven't tried them as I can alway open the garage door (except in extreme cold).
David
>Thanks for these great responses - I'm already searching the web for materials to try - and anxiously awaiting even more responses!!
Speaking of cold garages. I live in Buffalo. It gets cold here, perhaps you have heard. Bought a $10 goodwill dresser for my daughter's bedroom, that I have fixed up. Painting has been kind of laborious - every night this week freezing to death in the garage. Tonight I'll finally have it done. I'm pretty sure you aren't supposed to apply primer or paint in 30-degree temps, but it seems to be working.
RonZ
>Well it ain't purdy but I'm knocking holes in the walls [cement here in Israel] in order to put my dust extractor outside and an exhaust fan for the whole studio. Reason? Wood dust. These last few months I wake up feeling like I used to when I smoked. The finishes I use like tung oil, malamine, friction polish, sanding sealer, etc. only kill what's left of my brain cells from my teen years in California. =o) In short, you shuld think of some sort of filter/ventilation system anyways.
