Texturing with Ukibori pimples
Arch
>Ever since reading about it in M. O"Donnell's book, "Decorating Turned Wood", I've wanted to try a texturing technique he calls 'pimpling'. Having nothing to do with acne, it's known to the Japanese as 'ukibori' and widely used, but it was totally unknown to me. Not unusual. :)
Small depressions are pressed into the surface of a dry woodturning by forcing the end of steel shafts that have designs like chevrons, stars, crescents etc.) filed on the tips. Then the surrounding surfaces are sanded or turned down to the level of the depressions. Finally, held over steam the compressed wood expands and pimples in the shape of the design rise above the surface. I have never tried it because of the need to file the designs on the tips of small steel punches.
Now I see advertised in a recent 'Woodcraft' flyer, a set of 18 carver's punches for $40. They are used for background texturing in soft metals or wood and would seem ideal for making ukibori pimples or just for adding background texture to turned objects.
I'd sure appreciate opinions and advice of anyone who has used these punches or has experience with pimpling techniques before I add another 18 useless tools to my shop. TIA
Turn to Safety, Arch
Re: Texturing with Ukibori pimples
Doug Leite
>A friend of mine took a rod of between 1/4"-3/8" dia. and just ground a nice radius, like half of a ball, on one end. He used this with a small hammer to put dimples all around some pieces he turned, then proceeded as you stated.You can't be too aggressive in the depth or shape, as you don't want to break, or damage, any fibers in the process. Those were unique pieces with the "goose bump" effect that he got. I always wanted to try that, but I forgot all about it. Post your efforts.
Aloha
Doug
Anthony
>I wonder if you could use leather stamping tools?They are steel stamps that come in a veriety of shapes.Just a thought.
Dinyar Chavda
>Hi Arch:
I had read the same description, and did try it once with just using a center-punch. I was not too hapy with the results, as you really have to get the depressions pretty close to equal, and that is difficult to do--you have to pick a pieve of wood that has fairly uniform density(?) where you are going to punch, and then apply equal force at each punch. If you don't, it looks like a bunch of mistakes!
Also, it is really advisable to make a design before you start to punch, even if it is going to be random--again, I didn't, and it looked like what the big bad wolf was trying to do in the e-mail I sent you this morning.
Dinyar Chavda
>Arch:
I just googled "ukibori", and one the the pages it brought up was Janel Jacobson's site, and a very subtle example of ukibori. She used to do incredibly beautiful work in porcelain, and has now switched to wood. You can see her ukibori frog at http://www.janeljacobson.com/carvings/303.html . I guess it shows how good the technique looks when done subtly.
>Arc
it might work. I tried hammering dents with a ground over rod and found the results too uneven as mentioned before. I bought one of the spring loaded center punches and ground the tip over. This worked much better.
The letters and designs might work but they don't punch very deep. If the punches arent' consistenly in depth you will cut off part of the letter or design when you sand or cut away the waste wood.
The other problem I had with this method was the raised grain from the steam. It's time consuming to sand off the raised grain because the pimples get in the way and you can't power sand.
Richard Allen
Richard Allen
>Hi Arch
That sounds like a terrific idea. Having read the other responses, a couple of things come to mind.
The Japanese tend to turn endgrain bowls. With an endgrain bowl the density of the wood would tend to be the same all the way around. Our side grained turned bowls would exhibit different resistance to punching, sanding and "puffing" when steaming. All this to say that the effect would likely be more easily controlled on an endgrain bowl of the rim of a bowl or platter.
The raising of the grain is a concern. I am not sure how you would deal with that. Could the dimples be turned into pimples with some other sort of steaming? I am thinking steaming some other fluid, though I am at a loss as to what other fluid might work.
Good Luck
Richard
Brad Vietje
Brad Vietje
>Richard raises (ha-ha) a good point...
The specific examples in Michael O'Donnell's book are conical jewelry boxes, turned in end-grain (spindle) orientation. Thus, the density of the wood would be pretty consistant in most straight grained pieces of most wood species. I suspect finer grained woods like Maple would be better than a coarse wood like Ash to preserve detail.
He also uses a spring-loaded engineer's punch to get consistant imprints -- where does one get such a beasty ?
Safe Spinning,
Brad Vietje
Thetford, VT
OH, BTW: if you haven't stumbled upon this yet, accidentally touching the Esc button (say, by tossing a catalog on the desk) makes the entire message dissappear... consistantly, too...OOPS !
Fred Holder
>I purchased my spring loaded engineer's punch at Harbor Freight. It probably wouldn't stand up too well at punching metal, but it works great on wood.
Robert Cox
>TRy a needle gun.
AIR NEEDLE SCALER
19 hardened steel needles remove weld flux, rust, scale, paint, cement and other residues from irregular surfaces.
Speed: 4600 BPM
Stroke: 1-1/8''
Air pressure: 90 PSI
Air consumption: 4 CFM
Air inlet: 1/4 NPT
Length: 18''
Needle length: 7''
Weight: 6-1/4 lbs.
ITEM 1108-1VGA
$64.99
$49.99
Don Evans
>Brad:
They are more commonly called "automatic center punches" and most any hardware, Lowes or Home Depot will have them.
Don
