Re: Tear out on inside of Koa bowl
Mike Schwing from Md.
>John, I'll try to help.
There are many wears to deal with tear out, and sometimes nothing works other than sandpaper. Before resorting to that though...
Try stiffening the fibers instead of lubricating them, since that didn't work. Applying a coat of CA over the areas prone to tear out may help, as may any stiffening agent, white glue, shellac, sanding sealer, etc.. I have had better luck with stiffening fibers than softening them with oil, but others report exactly the opposite. Be mindful that any thing you add to the wood now may have an effect on the finish you choose later. For me, this is another reason to not use oil as it is harder to turn completely away than something that dries. I also find that thin CA goes everywhere it was not intended, so sanding sealer, such as Mylands Cellulose Sealer, winds up being my favorite choice.
Tool approach can also help (as can quality of sharpness). Not sure what type of gouge you're using, but if I use the roughing/shaping cut on my ellsworth grind to finish off a bowl I might get tear on the interior, but if I use his "flutes up", bevel rub cut (can be a bit of a pucker factor if you're not used to it), I can normally totally eliminate tear out, even on interior curves.
You may also find that different lathe speeds affect tear out. I tend to find slower speeds produce a finer surface for finishing cuts, but tool movement must change accordingly or you get ripples. I _think_ this is because the wood fibers are hitting the gouge with less force and tend to slice off cleanly rather than being pulled (torn) out by the sheer force of the speed at which then enounter the cutting edge.
Hope some of this helped (or made sense)
