First Bowl
First Bowl
First Bowl
Kurt Aebi
>I finally attempted a bowl. I had a small piece of Box Elder from a tree that had fallen over the brook that borders our property. The neighbor from across the brook came over and was cutting it up for firewood and I asked if I could keep some for projects. There was a small streak of red and a big split, there is a little bit of the split left and the red is but a trace, but the grain and worm holes really give it character. I call it a bowl, but it is really cup sized and a fellow at work said I should make a pestil (spelling?) and call it a mortar instead of abowl due to the very rounded bottom. It is 3" dia., 2-1/8" high and 1-5/8" deep.
I am going to cut out a piece of Purple Poplar for the next one!
img]http://www.thewoodworkers.us/phpBB2/files/box_elder_bowl-3.jpg[/img]
[img]http://www.thewoodworkers.us/phpBB2/files/box_elder_bowl-2.jpg[/img]
[img]http://www.thewoodworkers.us/phpBB2/files/box_elder_bowl-1.jpg[/img]
Re: First Bowl
Re: First Bowl
Kurt Aebi
>Oops! Here's the picture.
Re: First Bowl
Re: First Bowl
CHANK
>Very good first try.. Next time try to thin it some you will find it makes a big differance in the apperance
Re: First Bowl
Re: First Bowl
Carole in VA
>Looks like you are on your way! It does remind me of a mortar...now you need to turn the pestle to go with it. Keep spinnin'!
