Finishes for use W/Prisma Markers
Jennifer@Indy.USA
>Hello Everyone,
What finishes are you using with your Prisma Markers? I've used Watco Danish Oil and had good results, but I'm looking for something that won't yellow quite as much, but also won't remove the marker, obviously. I'm thinking of a wipe on waterbase poly. Also, I've only use my Prisma markers after I burn, and I'm wondering if those of you who use them without burning use a sealer of some sort first? I can tell that if I didn't have the burned lines to keep the pens from bleeding that it would be quite ugly. Any suggestions for this?
Thanks for all your help!
Jennifer
Re: Finishes for use W/Prisma Markers
Sorry....
Jim Shaver, Oakville Ontario
>Hi Jennifer,
I don't use Prisma colours, only crayons.....
You must be up to something...??
Take care,
Jim
Re: Sorry....
Jennifer@Indy.USA
>Very funny Jim.....Actually my latest project looks like I used Crayons! You'll understand that when you see it.
I know the anticipation is just killing you : )
Go ahead admit it...ha!
Joel Hunnicutt
>Jennifer, I think Art Listemann uses Krylon spray acrylic. It is water white. I think it would be a better choice than watco over color.
Jennifer@Indy.USA
>Thank you Joel!
Re: Sorry....
>Hi Jennifer,
I always anticipate seeing your work, seems like you are in a creative zone these days, that is great for us all to see your work as it develops before it sells...then we'll never see it!
Take care,
Jim
>Jennifer
Try Krylon Fixatif on a sample piece. It's the stuff they use to seal pastel chalk drawings. John Jordan recommended it too me years ago for some project. On some paints, dyes etc it doesn't change a thing and on some it does. Sometimes it's not enough of a finish and sometimes it's the perfect finish. I use it mostly for brushed and sandblasted pieces but it might be perfect for what you want to do.
IIRC that's what Andi Wolfe uses.
Jay in TX (formerly Ohio)
Fred in NC
>There is another Krylon product, the Triple Thick Crystal Clear Glaze, that seems to be the same, but in a thicker consistency. The advantage is that after two coats of that product I can level it off with some of the finer MicroMesh, and it does not look sprayed.
Wally Dickerman at Green Valley, Az.
>Jennifer, Andi Wolfe told me that she uses several coats of Watco Danish, a light coat of Krylon Fixitif spray, and several coats of Krylon UV resistant spray. I've tried her sequence a couple of times and it worked for me.
Wally
Thanks Everybody : )
Jennifer@Indy.USA
>I ran out and bought a can of the Krylon clear....before I saw the posts about the fixitif. I've never seen or heard of that before...so I'll keep my eyes out for it. I've got two coats of the Krylon on and so far so good.
Thanks again!
Jen
Re: Thanks Everybody : )
Don Evans
>Jen:
As fixitives are used mostly by artist to protect their work you may have better luck looking in art supply stores for it. Lots of them on internet, like Dick Blick etc., do a search on "art supply" may find one in your town. Michael's also.
Don
George Van in WI
>We sell it in our stamping and scrapbooking store in WI. Check the stores in your area if you have been unable to find it.
