A55 Smoothing Plane
Trouble with Stronghold Chuck,
Skip
>Having a problem keeping things in the chuck when cutting end grain. Working mostly with green birch, and not making huge pieces. Tennon is cut so as to not bottom on the chuck. Any suggestions?
Re: Trouble with Stronghold Chuck,
Barry Turner
>Make sure your tenon also has a 1/4" or so shoulder to but against the front of the jaws. This is very important. Don't allow the tenon to bottom out inside the jaws. The tenon's shoulder should bottom-out against the front of the jaws. Make sure the tenon diameter is slightly larger than the nominal size of the inside of the jaws. That should do it.
Re: Trouble with Stronghold Chuck, *LINK*
Fred Holder
>There is a possibility that the way that you are cutting into the end grain may be putting excessive pressure on the chuck mounting to tear the wood free from the chuck. If you've made the tenon slightly larger than the closed chuck diameter and have a shoulder for the jaws to butt against, you should be getting the maximum hold that chuck can give to your particular piece of wood.
I've watched pieces fly out of the chuck in the Great Egg Cup Race at the Utah Woodturning Symposium many times because people attacked the endgrain the same way they would hollow a bowl; i.e., from the edge toward the center. End grain should be hollowed from center toward the outside and it helps to have a drilled hole to cut from. I generaly use a spindle gouge with swept back wings and use the drill to make a hole at the center. Then cut with scooping cuts from the center up towards about 10:00. That should reduce the stress on the chuck mounting.
Good luck.
Fred Holder's Domain Page
Ron in Drums PA
>Sometimes green wood will shrink while you are turning and needs to be tighten up.
MikeinCapeMay
>Fred,
Speaking of end grain, have you ever hollowed with the gouge rolled over to your right, way over and then back hollowed from center to 1 o'clock, yes to the right and opposite side that the rest of the world does it? I've seen photos of Richard Raffin doing this, though not video footage and I've not seen anyone else using this method.
Thanks,
Mike
MikeinCapeMay
>Skip,
I agree with what's been said so far. I often check my chuck, green wood or not, to determine if it requires additonal tightening....on occasion it has. If your tenon is of the correct size and shape, is not bottoming out inside the jaws and has a shoulder to rest on, then you need to check how aggresive those hollow cuts are. Are you having problems with the chuck holding while your cutting the outside of the piece?
Mike
georgetroy
>I put thin Super glue on the back of the tenon and around it. The wood is reinforced, sealed and will hold better. During turning, as others have said here, tighten up the jaws. GT
I do it all the time...
Peter Teubel
>Its the ONLY way to hollow end grain . I have found that it takes someone literally holding your hand to get the gist of the technique. I have taught make folks that cut. All it takes is hand holding and in 5 minutes any turner can learn it. After that, its just practice.
let me rephrase that...
Peter Teubel
>Darn filter is ripping out my emoticons...
Its the ONLY way to hollow end grain (GRIN). I have found that it takes someone literally holding your hand to get the gist of the technique. I have taught make folks that cut. All it takes is hand holding and in 5 minutes any turner can learn it. After that, its just practice.
Re: let me rephrase that...
MikeinCapeMay
>Well I need my hand held. I suppose my tool angle is bad, the piece wants to and does throw my tool counterclockwise back onto the rest.....with dispatch!
Skip
>Thanks to all for the advise. I will try all the ideas and hopefully solve the problem. I am thinking I may be too aggressive with the cut.
