Tried & True Varnish Oil
Barry Turner
>Has anyone used this stuff on bowls? I just bought a can, but have not used it yet and don't quite know what to expect. Comments from the voices of experience please. Thanks.
Re: Tried & True Varnish Oil
>Barry
Never used it on Bowls. I don't know how it would hold up if the bowl is used. I've finished quite a few gun stocks with it. It' builds fast and looks good if you take the time to apply multiple coats and steel wood between each one.
Les Robison
>Tried & True needs to be applied in VERY thin coats and allowed to dry overnight before applying ensuing coats. It is great for "poping the grain" on highly figured woods. After allowing it to dry for 72 hours you can apply a top coat of a "finish" like lacquer. It also has the strong smell of BLO.
Barry Turner
>I was planning on using it much like I do with Minwax poly. Flood it on, let it sink in a few minutes, then wipe it off........so that I have an in-the-wood finish. How do you think that would work. Does it yellow over time very much?
Mike Rubes, Apex, NC
>Hi Barry,
I've been using this for about a year on basically everything I turn. The exceptions being the bowls I do for food, which I just finish with walnut oil. I've really good luck with applining the T&T on the lathe and then letting the bowl sit for a day or so and then buffing with the Beall system. I have been getting really nice results this way.
Good luck,
Mike
Charles Bjorgen
>You'll find that the Tried & True varnish oil is very thick in the can. The instructions call for bringing both the oil and the piece to be finished to at least 70 degrees. My shop runs slightly below 60 in the winter so I use one of those little coffee cup hot plate heaters to raise the temp of the finish to closer to 80 degrees. It spreads much easier at that temperature. I really like the T & T varnish oil. I've also used their Danish oil product but prefer the varnish oil.
