Spiraling tool for cutting threads?
Craig Daymon
>I was watching the Robert Sorby video on their 'Specialist Woodturning Tools - Part 1' (I recently bought the multi-tip tool) and it got into the part where they were showing off the tool with the rotating wheel cutters for creating spiraling.
Now I haven't tried it, but I would really like to make some boxes with threaded lids. I don't really want to spend $400 plus to do it and doing it by hand is supposed to be pretty tricky, but watching this spiraling tool looks like it could do it pretty easily with...maybe...minor modifications to the wheels.
Of course, for appearance, it would be necessary to turn away the beginning of the outside and inside thread because it won't start with a full depth cut, but taper to full depth in about a revolution and the wheel would likely be too big for some applications. But with a deep enough box, I think this would work pretty well.
Has anyone heard of using a spiral cutter in this way?
(I know there is a home-built power rig on Jean Michel's site, http://www.jeanmichel.org/thread.htm which still might not be cheap to make, as well as plans to make thread cutters from old chisels but a spiraling tool set-up looks easier.)
Sorry for the long ramble, but I wanted to try to get the idea across as clear as possible.
-Craig
Re: Spiraling tool for cutting threads?
john Lucas
>Craig
I have the spiraling tool. I don't think it would do the job. Making the female threads would be the real problem.
It is not that difficult to hand chase threads. I haven't played with it enough to be any good but it's not that hard to do and I think a little practice would make you pretty good at it.
Fred Holder has an excellent book on making screw threads using all sorts of methods. I would highly recommmend it. It will help you decide the best method. Check Amazon.com
You can build a homemade version of the Bonnie Klein, or Willard Baxter style threader. I don't remember where I've seen the plans but I may be able to dig it up.
Chuck Nickerson
>The plans were in ShopNotes
Stan
>Can these shopnotes be purchased?
Stan
Columbus, OH
Re: Spiraling tool for cutting threads? *LINK*
Fred Holder
>No, the spiralling tool cannot be used to make threads. If you have a high speed internet connection, e-mail me and I'll send you a copy of the article from More Woodturning where I tell how to make a thread chaser out of a bolt. The cost is less than a dollar and a little time.
As recommended my book, Making Screw Threads in Wood, will give you all of the options even explain how to make a simple threading jig. It is available from Amazon.com.
Fred Holders Domain Site
