Turning a baby rattle?
Mk
>Is it necessary to have a captive ring tool to turn captive rings for a baby rattle? I cannot think of any other way.
Mk
Re: Turning a baby rattle?
Joe Herrmann
>You can make your own from a small nail or a small allen wrench. All you have to do is to find some way to undercut the bead and you have it.
Joe
Mk
>Allen wrench? That's a thought. Are they hardened or does it matter?
Also, did you just hold that wrench or seat it in a tool handle?
Don Orr
>I ground some old screwdrivers to shape and they worked fairly well.
On a related note...
>...baby rattles are something I have always been *very* nervous about making. The potential dangers (and related liability issues) are huge, like if you fill it with BBs or something and the baby somehow breaks it or gets hurt or ingests something it shouldn't. Captive rings -- essentially all short grain -- just make the dangers worse, since they can be easily broken into sharp little pieces.
Just a thought from a grandpa. Please be careful.
Ellis Walentine, Host
Joe Herrmann
>You can always harden it with a torch but for the little bit of wood you will be cutting with it, I don't think it is necessary. I use a small file handle to hold mine that I make for turning ornaments.
Ellis is right though, babby rattles are touchy; be careful with anything that could be swallowed or whatever!!
Joe
Re: On a related note...
Mk
>Yes, that is very true. Thanks!
Lee Buck
>The wonderful and much-missed Palmer Sharpless used a baby rattle project as a teaching tool. He called his a 3 ring circus. He had his students separate the captive rings (3) with the point of a skew. I am not particularly skilled with a skew and I was able to do it. The cautions raised are sensible.
Don Henthorn
>Years ago, before there were all these fancy specialized turning tools I turned a raft of captured ring rattles with a half inch scew. Here is a pic of the only one I have left. I didn't finish this one for some reason. Note that the last bead on the spindle is unturned. So, the answer to your question is, yes, you can turn the rings without a special tool because I did it.
Don Henthorn
>As an added note, I turned a much nicer one for a granddaughter and she insusted on having that rattle with her at all times. She slept with it, banged on things with it, teethed on it, played with it, and din't part with it until she was nearly two years old. She still keeps it in a safe place and it will probably see duty with her kids. I never had one of these rattles break.
RonZ
>I actually use a bent nail that I put into a handle and ground down the tip. Another option which I hope to try is Nick Cook's rattles. It was in a fairly recent issue from the AAW where he routes out a cavity and fills it with dried beans and then turns the rattle. This pictue is from his site. He also addresses legal size for child safety.
Yes and No...
>Granpapis worry too much some times, In what now seems like another lifetime, when we were expecting our first daughter, I was helping a fellow to restore a partially burnt stairway, he was making the newels and me the spindles, one lunch hour I stayed at the lathe and was trying to make a rattle , he came and watched me a little and then he got to it and asked me to watch, first he discarded the piece of wood I was using, and took a look at other pieces I had,one slightly curly and the other a rather confused grain, both hard maple, I had to make too a tote for one of my handplanes, so he said to use the confused grain piece for that and of the other he made this using the skew, it is 6 1/2", the rings are 1 1/4" the spindle is 7/16 at the ends and tapers to 1/4". It never was sanded or had any finish.
It had originally 10 rings, my idea was that it could double to help learn to count, it did , on spades.
It survived our 3 daughters, during the tenure of #2, it lost a ring, not from chewing (it has zero thoot marks), but from being thrown.
2 cents
Jorge
