Sharpening bowl gouges?
Mk
>What wheel do you guys use (grit size) for sharpening your bowl gouges?
Re: Sharpening bowl gouges?
Jim Pugh, Ohio
>I use 60 grit on both wheels altho 80 would probably work. Finer wheels don't cut fast enough (in my opinion) and generate more heat in the process.
Carole in VA
>I am a newbie and may be doing the wrong thing, but I shape on the 60 grit and do quick sharpening and touch ups on a 120 grit. Seems to work for me.
Ruth in S.Cal
>Now I just use what came with the grinder. Before I used a cold stone but I went through it too quickly.
Rodney in Maypearl, TX
>120 works for me, but actually I think 80 or 100 would be just as well. It really depends on what you become accustomed to. Once you get the profile where you want it, a quick LIGHT touch is all that's needed to renew the edge. That's why 120 is not a heat problem. If you are regrinding a profile, say putting an Ellsworth grind on a regular bowl gouge, then the coarser wheel i.e. 60, is better as it grinds quickly and generates less heat.
Ruth in S.Cal
>I just watched Mike Mahoney's DVD. He uses 36 and 58 grit.
john Lucas
>MK
I use 100 because that's what came with the grinder. I think 80 or 60 would be better. I used to have a 60 and liked it but it does take a light touch. 100 is too slow when reshaping a grind.
Russ Fairfield
>A 46-grit is a coarse wheel, and a 120-grit is a fine wheel. Take your pick for those in between. There isn't enough difference between 60, 80, and 100-grit to worry about it.
JamieDonaldson
>Nobody mentioned what size tools you are sharpening. I prefer the 60/120 combination- 60 for shaping and 120 for renewing the edge, especially on smaller tools like 1/4" and 3/8"gouges.
