>Hello folks, Debating about whether to cover the concrete floor in the shop. We were thinking about either those snap together shop tiles/rubber fullsize mats/plywood with a vapor barrier. We don't want to epoxy and the floor is only 3 months old. We don't want anything thick (8 foot ceilings). Any issues with stability of equipment, etc? Any info would be greatly appreciated. Thanks in advance, Guy
>If it's relatively smooth, seal it with any latex concrete sealer, then apply a couple of coats of industrial grade liquid wax. Mop it once a year and apply another coat of wax.
Many will disagree with my recommendations, but I have worked on such a floor for the last five years, and would not change a thing.
>Guy - I've been through this recently. My concrete shop floor is now 11 years old. When it was 10, and after three coats of so-called "shop floor paint" from Lowes had peeled off, I decided to try the engineered wood stuff - laminate that snaps together and floats on the floor. That started buckling within 10 days. The factory rep and the dealer disagreed over how much was due to moisture and how much was due to the weight of all the machinery (the laminate has to be able to move), but they all agreed it hadda be replaced. Then I found out that there's a test that can be done for moisture - consists of weighing some calcium chloride crystals, putting them on the floor and covering them for 72 hours, weigh 'em again, crank some numbers through the calculator and get a result that indicates how much moisture is coming through. I would strongly recommend you do this test, no matter what you decide, ESPECIALLY if your shop is below grade. Any flooring retailer can order the kit. Anyway, in my case, they all decided I had the best chance of success with commercial vinyl tile. So they put that down, gave me a hefty refund on the laminate, and the vinyl is looking great a year later.
>My answer was similar to Dave's. My shop is in a walk-out basement so three sides are below grade but one is level with it. After six years the floor was looking really dingy, splattered, etc. I just sheetrocked the walls and painted everything, then the floor looked really bad. Being cheap I went with floor tile but used the cheapy self sticking stuff. It actually looks great and so far has been very durable. I've drug stuff all over it and it has held up well. Being it's not the commercial stuff where the pattern goes all the way through, I have taken precautions not to drag sharp objects across it.
With painted, sheetrocked walls, painted cabinets and floor tile I figure I now have a "studio" and can charge more for my stuff (that is, if I ever decide to start selling it...)
>I went another way with my basement shop floor and left the concrete floor alone under all of the benches and equipment but added the 2 ft. square interlock rubber matting for the walking and standing areas. This is much warmer and easier on the legs. The only downside is it is harder to sweep clean than the concrete. I used a grated style around the lathe as I knew this would be where most of the sawdust and chips would be collecting.
>The only thing I would worry about,is mold.Whatever you cover your floor with,just make sure you do some research on how to seal the floor from moister.I too have a basement shop with a cement floor,and have been looking for a more comfortable solution.If anyone has done something,I would appreciate some feed back on how it worked out.
>Tom - It comes in squares and in more than one size, but not interlocking. Held down with a troweled-on adhesive, of which there are a couple of different grades for different applications. Tbe brand name of my tile is Azrock (12 inch squares) and they probably have a website. The installer recommended them for durability. Armstrong makes the same stuff in a bazillion different color combinations, and they are probably the biggest manufacturer. It's the same tile that's on practically every school cafeteria floor in the country. Mine was installed by our local floor coverings store, but I imagine that Lowes and Home Depot have a large selection.
A dropped gouge will put a cut in it, I determined that fact experimentally the other day. But you have to look close to see it, and maybe it would be even less noticeable if it hadn't been a Glaser gouge. One good thing about this tile is that an individual tile can be replaced pretty easily - you heat the tile with a torch until the adhesive lets go, then just stick a new one down.
>I neglected to mention in my previous post -- when I had the fake wood floor put down (the one that had to come back up because of moisture problems), it was partly because of appearance and partly for comfort. One can get an extra thick pad underneath the laminate, and I had hoped that that would give me more cushioning. I had some foot problems a couple years ago that were probably caused by all those hours on the concrete. OK, so the fake wood didn't work out, but in the meantime I've taken to wearing running shoes - I think they're Nike - in the shop and using a pretty good anti-fatigue mat at the lathe. THe mat came from Viking OFfice Supply. Those two things together have made a world of difference to my feet. No more problems, even on the vinyl tile.
>Why not epoxy? As a facilities manager, I have installed all of the products mentioned here and can say, with no doubt, that epoxy is the best choice. Of course, I install the industrial brands and have no experience with the big box stuff.
I epoxy painted my shop floor and have been thrilled with the results. The floor is impervious to chemicals, oils, scratches, you name it. If properly prepped, you'll never do it again.
