ADVERTISE HERE - FREE TRIAL
lathe motor mount help needed
Mike L in Trabuco Canyon, CA
>Hi all,
A few weeks ago, I picked up a 1972 vintage Delta/Rockwell 46-111 gap bed lathe. It is mounted on a home-made stand with the motor mounted on a shelf below the headstock. The lathe speed is changed by a step pulley system, however, since the motor is rigidly mounted to the stand, moving the belt between pulley sets is very difficult.
To overcome this, I plan to build a hinged platform for the motor where the motor's weight is supported by belt tension. Before I proceed, I'm wondering about proper alignment between the motor pulleys and the lathe pulleys. What kind of tolerance for that alignment is necessary? Also, are there any other items I need to be concerned with? Finally, does my approach sound appropriate (or even necessary)? TIA!
Regards,
Mike
Re: lathe motor mount help needed
Walt C
>I used a motor mounted like that. You have to mount the motor frame so it won't rotate, because it is supported only at one end. there is a little jumpiness at the start, because the moter wants to climb the belt, but that is all.
Otherwise, it worked well.
Walt C
Don Evans
>There is another Delta motor mount similiar and what they did to it works well. It's from the 50's and I don't see why they didn't stick with it, probably cause it worked.
On your mount, if you want to do it, I'll try to give you the idea. Hinge the mount on the back side, the belt should be the right length so the front of the mount stands proud about 2 - 2.5". Mount a bar (metal) from left to right on the front mount plate with an eye bolt hanging from the bar. Drill a hole in the board below mount and run the threaded end of the eye bolt through it, place large washer and nut on the eye bolt.
You can then lightly (probably just finger tight) the nut and it will stop the belt climb and also allow you to pull the belt tighter if necessary. But if finger tight works, it just makes it easier to adjust, no tools. You can also trash the nut and use a handle with built in nut too.
Don
John in Abbotsford
>Mike I have a similar setup on my lathe such as that discribed by Don.
Since this pick was taken I've changed the motor and put on a steped pully since the expanding pully cause too much vibration. the lathe now runs nice and smooth
Is that a Walker Turner Driver Line lathe?
Clem Wixted, Jonesboro, AR
>John,
It looks just like mine and yours is the only other one I've seen.
Clem
Re: Is that a Walker Turner Driver Line lathe?
Bob Reeve
>Mike,
As far as alinement, make sure the motor shaft and the pulley shaft are paralell. Then use straight edge (or string) accross the face of both pullys and look for contact at the top and bottom of both pulleys. This assures that they are in line.
John in Abbotsford
>Yes Clem, it is a Walker Turner Driver Line built in 1936 I believe. I looked up this lathe under all the articles and cataloges of the OWWM website and found this lathe being advertised new at a price of $29.95 would you believe that?
Since I bought the lathe It came with a 1/3hp motor which was much underpowered so I put on a 1hp I also removed the expanding pully (reeves?) and put on a 4 step pully and placed it in line with the pully on the main spindle also installed a link belt, the lathe now runs very smooth. For someone wanting to try out this hobbie without investing a lot of money it was a good start. However since I am enjoying turning so much I have decided to sell it and would like to replace it with the Vicmarc VL175VS.
>My father in law bought his new for about that price and also bought every accessory they made for it except for the spinning tools. He connected a 1/3 hp motor to a jack shaft so he could get real slow speeds to do metal turning. I got the lathe when he passed away a few years ago.
I have replaced the motor with a variable speed motor but I need to mount the lathe on a better stand. It's on a lightweight wooden bench now that vibrates.
Don't you just love that 1X12 thread?
Clem
John in Abbotsford
>Clem,
The 1"x12tpi thread hasn't been a problem I've been able to get additional face plates from LV and there was no problem in getting the inserts for the SuperNova chuck either, including the LH tread for outboard turning.
Thanks all....
>...for the advice and suggestions. I'm off to Rockler to get some link belt and hopefully I'll be turning (n.p.i.) bigger hunks of wood into smaller hunks of wood by this evening.
Regards,
Mike
