new lathe
JR in RI
>I am contemplating making an upgrade from my entry level Record lathe to either a Powermatic 1352, or a Nova DVR3000. Anybody got anything to say about either? Other recomendations in the $2000-$2500 range? Thanks
new lathe
JR in RI
Re: new lathe
>I have had a DVR for two years and am very pleased with it. Sixteen inch swing and the head pivots if that is not enough. No. 2 taper in both head and tail stock, Indexing, reversing, easy to add a vacuum chuck, on and on. Speed change is much faster and easier than using belts. Came with a Super Nova chuck and am very pleased with that, too.
Hasn't Powermatic been bought recently? Who actually makes them now? You want advice from current generation owners.
Re: new lathe
Eduardo Sarmiento Hall-Lima Peru
>Hi look get your self a 2036 and you will be very happy
Re: new lathe
David Galloway
>I have no idea what numbers you guys are throwing around. The Powermatic 3520a is an excellent lathe, the best value. Other lathes are fine. I suggest you turn on as many as possible. I think you turned on a 3520 at Nick's. That should give you a start. Then, try a Poolewood, a Jet, a Oneway. Tell your local chapter that you are considering such a move and ask if they would let you turn. My hunch is the Powermatic will be the one for quality and value, but look at everything. Most importantly, have fun finding out the right lathe for you.
Re: new lathe
n2wood
>I've got one of Oneway's new 1640 lathes and love it! It runs just a little bit more than your budget but for me it will be the last lathe that I'll ever need. No more upgrading for me. I just can't see ever wanting more lathe than this, I have the out board bed that will allow me to turn up to 24". It's smooth, quite, and sturdy as all get out. That combined with the service from Oneway well like I said it's all the lathe I'll ever need and haven't had one minute or regret since I've turned it on for the first time...........
Dean
