Oneway 1224 or Nova DVR
Dave in Oakville
>Hi Guys,
I have been lurking/drooling here for quite some time I am a rookie and I am about to buy my first lathe. I have turned on jet mini and had a number of lessons on Oneway 2436. I would love to buy a 2036 but do not have the budget or desire to spend that much on a first lathe however, I do intend to compliment either lathe with high quality tools and the wolverine sharpening jig.
My interests range from bowls to hollow forms and especially spindle turning for furniture parts. I accept I need to buy a bed extension for both lathes but would appreciate any thought you might have on the Oneway 1224 or Nova DVR. I expect this lathe to meet my need for at least 3 - 5 years and expect a good resale value on either one if my interests outgrow the lathe.
Thanks in advance for your input.
Re: Oneway 1224 or Nova DVR
Eduardo Sarmiento Hall-Lima Peru
>Well by all means the one way ,is by far the best you can get in that price and the quality is great,also it would be easier to re-sell
Jim Pugh, Ohio
>Also consider that the Nova DVR has a larger swing and a rotating head which some folks find real handy for bowl work. I have a friend who has one of each. He turns larger stuff on the Nova and smaller stuff on the little Oneway.
Even tho they are both good lathes, you are not comparing apples and apples here.
Scott Greaves, Blackfoot Idaho
>Hi Dave,
I have the Oneway 1224, and I think it is a wonderful lathe! I highly recommend it! Until you start getting into big bowls this lathe should do just fine, and it really doesn't need to be "moved up from". If you get one, I do recommend that you get the bed extension with it. I didn't, and ended up buying it later. It would be nice to have the factory fit the extensionon there for you!
I can't speak to the DVR. From all I know about it it is a fine lathe. I think you would be happy with either one!
Scott.
Bob Tabor
>I own a Nova DVR 3000 I have had it about 10 months now. I started on a Jet mini and I went through the same process which lathe to buy. I decided on the Nova because of all it's features and price. I have no complaints or problems with the Nova so far. I will buy a large Oneway some day when I have the room and sone more experiance. I will keep the Nova for finish and other work, might as well have two lathes. Once hooked on turning there is no going back so pick one and get turning.
Tough Choice...
Peter Teubel
>Both are excellent lathes. The fit & finish is better on the Oneway, but the DVR has more capacity and power. Nice thing about the 1224 is that its a nice compact self-contained unit. You'll have to build or buy a stand for the Nova. I would think the Oneway would hold its value better than the Nova (purely unscientific reasoning based on the fact I've never seen a used 1224 for sale).
Flip a coin...you'll win either way.
Bill MacLachlan
>I have had a DVR for about a year and highly recommend it. I also looked at the Oneway but did not get a warm feeling from them when trying to deal in Canadian funds. I thought the DVR would allow me to do more things.
Went through that decision in December
Garrett in Victoria BC
>and decided on the Nova.
The OneWay is a hand-made tool, and has a deservedly high reputation. However, so does the DVR and its greater capacity, its swivelling head, and the fact it comes with the excellent SuperNova II chuck and worm screw all helped make up my mind. No regrets.
Cheers, Garrett
>I have the DVR and have used it for a little over two years. The electronics on mine went bad, but the company replaced it without question and at no expense to me. I would make the same decision again. I get a lot of use out of the free chuck.
My only regret is that I did not buy a bed extension. Did not think it was important because I turn bowls and hollow forms almost exclusively, but I would have been able to push the tail stock further back out of the way rather than remove it. I bring it up against heavy out of balance blanks. Have never had the desire to turn a spindle longer than the existing capacity, but I can still add the extension if I want to badly enough to rebuild the stand.
Re: Oneway 1224 or Nova DVR *LINK*
georgetroy
>My DVR is 2 1/2 Years old. I have it mounted to a 500 lb. work bench. The 16" is great way to go. The Swivel head allows you to use long bowl gouges. Thread is a standard 1 1/4 x 8. I do have other larger lathes, but for the smaller stuff this is the one I go to. I like the control box right at hand for easy start, go & stop. You could check the Nova group which has 276 members.
Nova owners
Steve Mushinski
>Dave,
The OneWay has a very good base already. The lathe runs perfect. Fit and finish is very good. Everything except the bearings and motor controller are made in house. You know where to go get parts, which will be next day delivered. This is not a slam of the DVR as I have heard good things about them. Just my opinion on the 1224. Pricey yes but it might be concidered the best. If you want to talk more about it email me or look up my number I'm just over in Oshawa.
