question making wooden jaws for Nova Midi chuck?
mike recchione
>Hi - I'm a fairly inexperienced turner (mostly a neanderthal kind of guy, but have done a little turning). I own a Delta Midi, and am considering a number of projects that would make it nice to have a chuck. I've been considering the Supernova Precision Midi chuck, and have seen a lot of positive reactions to it here.
For one of the projects I'm considering, it would be nice to be able to make a set of non-marring wooden jaws for the chuck. (I'm planning a run of Judi drop spindles for my wife and her spinning guild.) Is it possible to replace the metal jaws that come with the chuck with shopmade wooden ones? Or is even thinking about this silly?
Thanks in advance for any replies.
Re: question making wooden jaws for Nova Midi chuck?
Re: question making wooden jaws for Nova Midi chuc *LINK*
Ron in Drums PA
>Here is an article by Mark K.
http://www.woodcentral.com/cgi-bin/readarticle.pl?
>I have two Nova chucks. One is the smaller one where you use the two bars to tighten it. I have always been disappointed in that one. I found it hard to tighten it, you need three hands. Perhaps my expectations were too high, but I found the chuck lacking in gripping power and had a few pieces come loose. I also have the Super Nova, the larger one that uses a large chuck key like the one for a drill chuck. This is a much stronger chuck and does a much better job. They have improved it recently by coming out with the Super Nova2 and it uses an Allen wrench to tighten it. It appears to be a significant improvement over the key.
I now use my Midi Chuck with a set of Cole jaws, metal ones similar to the wooden ones shown in the article mentioned above. It's great for that because that application does not require a lot of holding power.
100mm jaws have threaded holes in them specifically for adding wooden accessory jaws. They require metric machine screws, but the answer to your question is, yes, you can make your own jaws or even pads for existing jaws.
I am not familiar with what you are trying to make, so I don't know how I would approach it, but you can also make your own "chuck" in a number of different ways. Faceplates with various blocks, Hollowed pieces with hose clamps around them and so on.
My point was that I think you will be happier with the larger chuck whether it is a Nova or one of the other brands. I found my smaller one nearly useless except for the Cole Jaws, now its good.
Barry Irby.
Ace Foster in Ben Lomond 95005
>I've made several sets of jaws for my Nova & SuperNova chucks. I've had such good luck with them that I can't see why it would be worth the trouble to get some of the metal jaws that are available. I've used baltic birch plywood, glued up to whatever thickness I thought I needed. It's worked just fine.
Ace
Ace -Could you post some photos?
Clem Wixted, Jonesboro, AR
Thanks, and another question
mike recchione
>Thanks to all of you who responded.
I think Barry has led me to reconsider the Midi chuck - I checked their website and the two bar, three handed tightening system is somewhat daunting. While the particular project I have in mind requires holding a 2" diameter disk about 1/2" thick in the chuck, which should be fairly doable even if the holding power isn't that great, I would ultimately like to try to turn some small bowls, goblets, etc. So, unless I hear very different stories about performance, the Nova Midi is out.
I'm probably going to try a workaround that doesn't require a chuck for now. But for the future, is there another chuck that would be suitable for the Delta Midi lathe, and that won't break the bank?
Thanks again,
Mike in NJ.
Brad Vietje
Re: Thanks, and another question
Brad Vietje
>Mike,
Seems like you are trying to grip small items (I remember 2") w/out marring, and not big Cole jaws, and such. The standard 50mm jaws in the Nova/Supernova line will work fine if the diameter is close to the inside diameter of the jaws (~45mm), and the turning is protected with a layer of paper towel or tape. The jaws are smooth on the inside, with a cylindrical base and a short, 15 degree dovetail at the tip.
Another option for something like drop spindles, especially if they are to be fairly uniform in size, is to make a wooden collet that fits your chuck jaws at one end, and fits the desired outer diameter of your spindle on the other.
You essentially make a very short cup, with the proper size tenon for chuck jaws, and a short cylindrical recess for the spindle at opposite ends. Then carefully cut make a few bandsaw cuts about 3/4 way from one end to the other, from both ends, in alternate pattern. When you squeeze this with the chuck, it will contract to grip your spindles. This should work for pieces a little larger than your chuck jaws, as well as any size smaller. You could make a set of a few desirable sizes.
I don't have a photo to share with you, but this technique and equipment can be seen in very nice detail in Robert Chapman's excellent book, Woodturning, A Fresh Approach. I may be able to scan and send a pic from the book -- contact me off-list if you wish.
Safe spinning,
Brad Vietje
Thetford, VT
>Mike,
Perhaps I was unfair to the Midi Chuck. I have learned to lock the shaft on the lathe and hold the work piece in one had and snug it into place with one tommy bar, then use both bars to cinch it tight. For small disk as you describe, it would be a very adequate chuck, but I still like the Super Nova better.
If you are going to turn a number of disks the same size, you could make a chuck as described above or you could make a "jamb" chuck. If your disks are all identical you just cut a sightly tapered hole in sacrificial block or face plate and force fit them in. you can drill a hole through it and use the breaking bar on the lathe through the headstock to tap them out.
Barry Irby.
Woodturning Design article
Al Kapocius, Metro Greendale
>Winter and Spring 2005 Woodturning Design magazine articles by David Reed Smith on Eccentric Woodturning show how to make a two (wood) jawed chuck to hold a square or rectangular workpiece. Eccentric turning is easy by sliding the workpiece off center.
Jaws are what look like 2x4 stock bolted to only two of the chuck locations. Mayhap the jaw faces can be turned or modified for your particular requirement. The articles may provide further ideas. Basically, yes, you can mount wood jaws on a chuck.
Al Kapocius
Thanks everyone!
mike recchione
