More Sanding ??'s
More Sanding ??'s
More Sanding ??'s
Lou Krupnick
>As a relatively fledgling turner whose cuts are not always up to par, any advice regarding sanding & systems using the power drill route, such as velcro v.s. PSA attachment, use of backing pads, etc. For turning bowls does 2" or 3" dia. make more sense?
Thanks in advance, Lou
Re: More Sanding ??'s
GeeSeaWhy
>H&L (Velcro) you can take off and put back multiple times. PSA is more of a one-shot deal - it won't stick a second time.
You can use 2" discs to sand a large bowl a lot more easily than you can sand a small bowl with 3" discs.
I used to use the wave discs but never found the fingers to be any advantage, and the discs both lose their grip and go dull faster than the ones Steve Worcester sells at www.turningwood.com/
Graeme
Greg in Oshkosh
>I prefer the 3" velcro system. 2" may fit in more bowl sizes but for what I turn it's even slower than 3" and I hate sanding. BTW the best advice for sanding endgrain on bowls is to give it a coat of wax, sealer, varnish etc. This stiffins the fibers and allows you to sand it. I prefer a 1:1 blend of wax and turpentine. I hand sand with this applied to the endgrain. Use 60 or 80 grit paper. After the bad spots are gone I switch to the 3" velcro discs.
John Trant (Baltimore/DC area)
>I have found using the largest pads possible is far better than trying to use the pad that will work for the smallest turning that you will do. Personally, I use the 5" pad preferentially and, if necessary, I will use a 3" pad. I have and use 2" pads but primarily just for special situations. I bought my pads from Steve Worster and Bruce Hoover. I purcahsed the small H&L discs from Steve and the 5" H&L discs from Klingspor.
N.B. Worn out 5" discs are still perfectly good in the center from which I can cut out a 3" or 2" disc.
John
An article I wrote
Mike Schwing from Md.
>Lou, here is a copy of an article I recently wrote for one of the turning clubs to which I belong. Hope it helps.
Sanding on the lathe � by Mike Schwing
Every woodturner likes to take advantage of the lathe to help with what is typically considered a chore � sanding. It is hard to resist the fact that you can spin the work and hold a piece of sandpaper against the work and the entire surface is quickly sanded. However, the results from doing so are far from extraordinary. Circular scratches that scribe the entire diameter of the bowl from rim all the way down to the center are inevitable with this method. This type of sanding scratch is very difficult to remove and they are one of the telltale signs of a turner who does not have high standards for his work.
These scratches result from the work surface spinning so quickly that the same tiny pieces of sanding grit remain in contact with the work for several or many revolutions. The problem can be minimized with hand sanding in a few ways, but rarely totally eliminated.
If you are committed to hand sanding with the lathe running, the following tips may help you minimize these types of scratches.
1. Keep the sandpaper moving randomly over the surface. Never let it rest for even a moment on the spinning surface.
2. Run the lathe at a VERY low speed. This minimizes the length of a scratch as you move the sandpaper over the spinning surface.
3. Do both number 1 and 2 at the same time.
4. Do not skip grits.
5. When you have finished with one grit, stop the lathe, lock the spindle and go over the surface with that grit by hand, with the grain direction. You will normally be able to remove any circular scratches.
6. Wipe off the surface with a cloth to remove any lingering sanding grit. If you skip this step you will often have scratches reappear with the next grit.
7. Move on to the next grit, and repeat steps 5 and 6 and 7 until you are satisfied.
You will probably find that your surface appearance has improved quite a bit if you were not doing something like this before. One of the reasons is that hand sanding with the grain will reveal surface detail that cross grain or circular sanding cannot. This is due to the light reflection characteristics of the sanding scratches and not technique. Make sure your last few passes with the sandpaper go with the grain.
Power sanding
A more productive method of sanding involves not only lathe rotation but sandpaper rotation as well. There are many �power sanders� available on the market. I will make only one recommendation based on what I use � the �wave� sanding discs. (www.woodturnerscatalog.com) and their soft backing pads. This system is used in a hand held drill and produces excellent results. The method is exactly the same as above, except that you are not holding the paper by hand. The faster the drill speed the better, as is the slower the lathe speed the better. I use grits in the following order � 80, 120, 180, 220, 320. I then move to Micro-Mesh sandpaper from 1500 to 12,000 grit if necessary. With a high drill speed, step number 5 above should take only 15 or 20 seconds per grit. Just go over the surface very quickly and lightly with the spindle locked. When you do it correctly all scratches disappear.
I power sand just about everything in this manner and have no fear of people critiquing my work up close for sanding scratches. The one area I still have to work on is sanding details like rim treatments or bottom ogees, etc.. It is hard to get up close to them without destroying the detail. I have found these little gems hard to beat for that�.Sanding sticks by Woodcraft http://www.woodcraft.com/family.aspx?DeptID=2070&FamilyID=274
I hope this helps some. Please feel free to contact me with questions. I am on a mission to rid the world of sanding scratches.
Re: An article I wrote
rprevett
>Thanks a lot for that article Mike, a copy is going to my sanding folder.
rick
Lou Krupnick
>thanks all!!
