>My first bowl. I gave up on the paulownia and tried a piece of dry walnut. As Mr. G would say, it has a dumpy bottom, but at least I got it off the lathe in one piece! What do you guys use to sand the inside? I can't seem to do a very good job with fingers and sand paper.
>Carole, Power sand. Richmond Wood turners Club buys little Velcro disks and the sand paper. We go together and place an order and whom ever we get it from gives us a discount. We buy two inch and three inch. Just chuck them in a drill and sand away. You will never go back to hand sanding, at least not for all of it, just the details. Woodcraft and Klingspor have the stuff and I'm sure Packard and all the others.
>Looks good Carole. If the bowl is big enough I use the hook & loop pads on my portable drill. Same as for the outside. I have 3" OD and made some 2" OD for the smaller bowls.
Your bowl looks great. I use cloth backed sand paper and do most of my sanding by hand. I cut my paper into strips about 1.5" wide or even narrower if the bowl is smaller. I use strips about 2-3" long. This way you don't get bends and creases in the paper that make more scratches than you get rid of.
>The power sanders everybody is talking about are great. I have the two and three inch setups and wouldn't be without them. However, when you are just starting I know you can't go out and buy everything. While the bowl is still on the lathe, just take sandpaper and hold it against the bowl, rotating at a farily low speed. Just keep working down from 60 or 80 grit to about 400. Each grit just removes the lines from the previous grit. It works!
>That's a nice looking bowl, Carole. Congratulations!
Like most other people, I use H&L sanding discs (2") on an electric drill, sanding with the lathe running. Run the lathe slow and the drill fast. The holder for the discs is rather stiff, which makes it bounce around until you figure out how to present it. You'll find it much easier to use with an extra-soft pad on the holder - Packard Woodworks sells those, along with all the other bits and pieces.
>Dominic, How are you cutting the sand paper? I used to cut PSA one with a circle cutter in the drill press, but I don't think it would cut the fabric for the Velcro. I Had thought of this , but assumed the sand paper would dull whatever cutter you use pretty quickly.
I'm cheap and a pack rat, so sometimes I use the "used" 3" disks on the 2" mandrel. In most cases its the edge of the disk that wears out, so you can use it again by cutting it down. Most of the time I don't even cut it, I just use the smaller pad to danger where the pressure is on the grit.
Also, with the club buying them in bulk they are not that expensive and I find I can sand a bowl like Carole's with one of each grit or less.
I want to find the pads with hex shafts and have one for each grit. Use a quick change shaft in the drill and just change the entire disk. I think this would have a number of benefits. You could leave the paper on the disk until it was worn out, rather than having a number of half used pieces floating around. The Sawdust clings to the cloth backing and makes them difficult to remount. I visualize a board with about six 3" holes about a 1/4 inch deep and about six more for 2" pads. Each one labeled for a grit.
>Carol- one of the power sanding benefits not mentioned is the lack of wear and tear on your fingers and the efficiency of the process. The heat buildup from hand sanding often leads to heat checking in the wood as well, so check out the 2" Velcro backed power sanding options available from many sources.
Mark Kauder wrote an article (feature in the Articles Section of Woodcentral) about using a bandsaw to cut the sandpaper to size.
I however (being a lazy cuss who didn't feel like changing out the blade on his bandsaw), chose to use a straight edge and a utility knife. I used a 4' long x 6" wide x 1" thick strip of hardwood as a "backer". The backer had a line drawn 2" from the edge. All I did was match up the edge of the sandpaper with the line, position my 5' long stainless steel straight edge on the line, and cut. The I'd take the 2" wide strip, turn it 90 deg and repeat the process.
>Carole, if you check Mike S.'s post today entitled 'An article I wrote', under a Sanding ??? topic, he lays out the right way to sand while on the lathe. He's on a crusade, you know :)
>Excellent first bowl! I use the Sorby sandmaster. It's a handle that holds a sanding disk on with velcro and turns via the turning of the bowl. I prefer this over a power sander for many reasons.
