Veritas - Innovation in Tools
for jet 1236 owners
for jet 1236 owners
for jet 1236 owners
David E Whiting
>I am considering putting a vacuum chuck system on my 1236. Can someone supply the exact [parts and vendors I will need and comments on how their 1236 worked with the vac system
TIA
Dave
Re: for jet 1236 owners
Brad Vietje
Brad Vietje
>David -- I'm surprised no one has answered yet. I have the 1236, but no vacuum capability yet. You might want to re-post your question as "Vacuum Chucking Question" ; I think the specific hardware just needs the correct threads, etc...
Safe spinning,
Brad Vietje
Thetford, VT
Re: 1236 vacuum
>As far as a connection goes, the EZ-Vac available at Packard is simple, very effective, and cost efficient. Composed of two fittings and a length of 3/8" hollow lamp threadrod, it's inserted through the MT and held with the rotating fitting from the outboard side. You simply mount the MT fitting, then trim off the excess rod to allow the outboard to fit snug. I added a rubber "o" ring to the MT fitting for better seal and the same thing can be done on the outboard side if you like. Nice thing is that if you upgrade and sell the lathe (whatcha mean "if"), you can get a new piece of threadrod to fit the new machine.
Connection is then made with 3/8" hose with a 1/4" adapter. I routinely pulled up to 27" on my 1236 with that connection.
Now vacuum pumps is a different question, but don't forget to incorporate a line bleeder valve and vacuum gauge in your set up so you can adjust the pressure and have an indication of how well your seal on the piece is working.
Mark
Ron in Drums PA
>David, I'm in the middle of building one for my 1236. If you can hang on for a couple of weeks I'll post some images.
what other woodturnings forums may answer my quest
David E Whiting
