HELP!!!!
HELP!!!!
HELP!!!!
Carl Bordelon
>The Purple Heart bowl I am turning is PURPLE.
The shaveings on the floor are a nice pretty shade of purple but not the bowl,it's more brown.
What am I doning wrong.
Please tell me I can fix this.
Re: HELP!!!!
Re: HELP!!!!
john Lucas
>Carl
Don't worry about it. It will change color when you get sunlight on it. Put a fresh cut board outside for few hours with a quarter laying on it. You'll be able to see the outline of the quarter.
Re: HELP!!!!
Re: HELP!!!!
Carl Bordelon
>OK THanks.
Will it still go back to being purple if I have some wipe on poly on it,or should I remove the polly and then set it in the sun?
Of Coarse it's fixing to Rain so there is'nt much sun today.
Re: HELP!!!!
Re: HELP!!!!
Ron in Drums PA
>There is no way to stop it from changing.
Re: HELP!!!!
Re: HELP!!!!
Carl Bordelon
>OK guys,the purple is returning.
Thanks for the help.
Us crazy cajuns ain't use to these exotic woods.LOL
Re: HELP!!!!
Re: HELP!!!!
MikeinCapeMay
>Be sure to use a UV protective finish or at least keep it out of the sun. When freshly milled/turned it's brown and it does indeed go back to purple, however it will darken considerably with age back to a brown and on occasion even darker.
Re: HELP!!!!
Re: HELP!!!!
Carl Bordelon
>OK I will do that.
Thanks for the info.
Re: HELP!!!!
Re: HELP!!!!
Big Mike (In SW Indiana)
>Well... may sound dumb but... one way to help keep your color from being destroyed by UV oxidation is...
put a 2 or 3 coats of Armor-all on
before your finish... I know... sounds crazy but... it does work (ya the same stuff you use in your car to protect from UV)
I have used it successfully on a Purple Heart platter, and some pins... out of Purple heart, pink Ivory, redheart, etc.
Big Mike� So. Indiana
