ever heard of a hercules dust collector
chad smith
>Found a dust collector called a hercules. Does anyone know anything about them.
Re: ever heard of a hercules dust collector
Wood Spinner
>Hi Chad
I did a search on the name Hercules and came up empty for vacs. The only thing I might say is look at it. Be sure it is not 3 phase. In your case it may be better for 120 VAC unles you ran 220 to the shop if you did then 220 is best. Turn it on check the vacuum to be sure the vanes are not worn out and listen to it for balance. Let it run for a bit and be sure it does not get hot. If you can not find it on the web I would guess there are no parts available for it.
Another thought is that if you are going to bolw out of the shop like I do you can buy a new blower only from Penn State and others for the same money. Penn State 1 1/2 hp DC3-1M $ 219.95 850 cfm - 1 hp DC660P $ 139.95 660 cfm.
I would go for the 850 cfm and buy new.
Dad
