Spalted birch bowl
keith zimmerman, Normal IL
>Greetings all,
I've just been hanging for a while, but thought I would post a photo of my latest challenge.
This is a bowl from spalted birch. I had had a heck of a time getting it firm enough to turn. It is about 5" in diameter, 2" deep, and has 3/16" walls. It was then sanded to 320 grit. So far, I have one coat of Minwax Tung Oil Finish. It will get a few more coats, then a good buffing.
This wood was extremely soft and punky, almost too much so. I first tried soaking the blank in a mixture of Elmer's glue and water, which was only marginally successful. After starting the turning, I got into more very soft wood and tried to use CA to firm it up. Big mistake...the CA reacted with the residual PVA and started foaming, like I had sprayed the piece with accelerator. I chucked it back up and turned off the foam, then soaked the bowl in Minwax Wood Hardener. What a stench!! That did the trick though.
Thanks for looking. I'm not particularly looking for critique, this is a very plain form and not completely finished yet.
keithz
